Good morning!!!!
   / Good morning!!!! #193,461
Those connections really have to be done correctly. You have to use a burnishing type flaring tool and Nylog lube/sealant.
It’s a very safe bet that a leak on a Mitsubishi, Fujitsu, or other major league offering is on the line set.
He noticed the wrong sealant was used
   / Good morning!!!! #193,462
This, too:
good idea, that looks like fun
but drilling down they have limited car parking and only parking in parking garages, a clear fail for an rv.
So not sure I can get there...
they have a place in the back for busses. Maybe if I call they will allow me to park in the back.??
I have same problem parking at tractor museum
looks mighty tight
   / Good morning!!!! #193,464
I recall that for composite more closely spaced support beams had to be used to prevent sagging. Treated 2x's were closely spaced for the stairs and balconies and no sagging after all this time even on the wide stairs
   / Good morning!!!! #193,466
Trex says they support 16" OC, but I have my doubts. I will probably just go with wood again, but will price both.
   / Good morning!!!! #193,467
Good (Tuesday) morning. Overnight Low was, again, 11.1C and it's presently 14.5C, partly cloudy with some gusting wind. There was 6.0mm in the gauge @ 0900.
Nothing 'pressing' on for today. The shed tank pump seems to be behaving... which means I'll be keeping an 'ear' on the situation.
   / Good morning!!!! #193,468
even though my rv is now cooperating, thought it would be handy to have a 20amp spare gfci.
Seems I have a choice of ground fault or ground fault plus arc fault. The latter apparently being a newer standard?
Ten bucks more, 30 vs 20, so I went for the double unit. Figured sort of like having my smoke detectors and gas detectors
being in same unit. Hopefully more protection and not more faulty trips.
having water in your live receptacles certainly creates a ground, which I witnessed.
when does the arcing start?
I have one gfci in rv, in the bathroom, where the bidet seat plugs in.
Surface mount, so easy to swap out the unit. But since the one in there likely works fine, so far...,
I'm happy to just carry a spare.
More likely to have an issue with the one on the garage wall.
I'd love to run 50 amps to the garage. 15 going on 13 is pretty inadequate...
If I ever want an EV car or plug in hybrid, going to need more juice.
would be nice to be able to run motorhome a/c on garage outlet but it just trips the breaker
in the house.
when i get home from my trip, I hope to put the rv in a campground in Hatfield that has very reasonable monthly rates.
Then I can get my car back in the garage for the winter.
The golf cart won't fit in the new shed, so I ordered an outdoor cover for it,
but new shed should hold Gravely and JD mower.
hopefully I can move a lot of gardening stuff to the outside shed leaving more room for
woodworking and neater storage. My storage skills are dubious.
   / Good morning!!!! #193,469
Good Evening Dennis,
Dennis, I used Trex on my Ct deck with 16”OC with no adverse problems! The deck is 20ft long, boards grooved both sides so I used the tee shaped hold downs !
   / Good morning!!!! #193,470
I have procrastinated long enough. Tomorrow is my day to drive up to shed shop
in Quakertown and order the shed for a Nov 1 delivery.
That will be fun to come home to.
Spending extra money for Amish made quality construction.
hopefully my last garden shed
spec'ing the oversized door hinges, several hundred more but don't want saggy doors.
One door will be a 6 footer with double doors so 50 inch mower deck can get by.
Am having the wood doors stained light brown and I'll spar varnish them. Natural wood IMHO simply looks nice.
pretty sure most of you agree
rest of shed is some vinyl siding, shingles, all greys and then dark green trim to match the garage and cottage.
no one can see it anyway, totally hidden behind garage.
But I wanted those natural wood doors to be the focal point.
of course I will have the optional window flower boxes
how I hang up tools will be decided after I park the two mowers in there and see what room is left.
There will be a potting/work shelf at one end.
add on cost for a full heavy duty floor is substantial, but necessary.
site prep is over a grand, that I will take care of myself or my lawn guys will.
I already had a 7x7 site leveled and stoned, just need it expanded to 8x12
no electric or complications
just as much shed as I can put in and stay under 100sf.
at 101 sf, the complications begin
2021 Chevrolet Equinox LS SUV (A55758)
2021 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Golf Cart (A55853)
Golf Cart (A55853)
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
Wood Native American Statue (A55758)
Wood Native...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
