Our Tractor was delivered today
/ Our Tractor was delivered today
I bought my Deere 955 knowing about zero about compact tractor operation. After 15 years: I can say it takes a bit to learn your tractors personal space so stay away from damage able stuff like buildings, cars etc. when I kissed the house with my bucket while mowing I not only crunched the clapboards but the sheathing behind it. Since you missed even the delivery guys input you should try to locate some neighbor farmer with blue tractor experience to spend a beer or two going over your tractor and operating tips. I haven’t seen what you are trying to do with this tractor but the low load height carrying advice is critical. Consider adding beet juice to your rear tires if you plan to dig and lift a lot with your loader. Some additional implements are not only brand but model specific so consider this aspect when buying more; you will be locked into that model or have to sell it all and start over with a newer model. As I wore out my first 955, I ended up buying another for that reason.
Found out a buddy at church has a tractor, going to talk about getting together with him. Great idea on finding a person around here with the same tractor as mine. Appreciate the input, sir!
Box blade that is wider than width of tractor makes the best counter weight (loaded rear tires also). I have a Workmaster 50 and 8 ft box blade works great.
My tire width IIRC is a foot narrower than my box blade, or a tad more. 6' box blade.
/ Our Tractor was delivered today #74
Careful with the rear attachments.
I learned the hard way as a kid.
The rear attachment swings way out when you make a turn.
It doesn't follow you like a trailer.
If it's 4-5 feet behind you when you turn it will hit anything that's in that radius.
So it's not just what's in front of you, keep an eye behind you.
/ Our Tractor was delivered today #75
Ain't that the truth. I've hit more things behind than in front. The backhoe sticks out a long way as does the brush hog. Both are 7' or so behind the tractor.
/ Our Tractor was delivered today #77
Best advice I can give is, the only dumb question is the question that isn't asked. There is a big difference in ignorance and stupidity. Both usually get the same results. Ignorance is not knowing, stupidity is knowing better and being a dumb ass. Farming is one of the most dangerous vocations there is. The equipment and activities involved are unforgiving, almost like playing with a loaded gun. The tractor by itself isn't dangerous by itself. Put it in the hands of ignorance and it can be lethal.
/ Our Tractor was delivered today #78
I see no one has talked about hills. Pay attention to hills, don't go sideways, keep the bucket low if loaded, only go down facing forward and the bucket low. I use a heavy duty box blade for my counterweight.
I one time didn't have it on when I was going down my driveway with a bucket full of gravel. I ended up with a pucker factor. I lowered the bucket almost to ground level as the brakes were useless. With the brakes only on the rear and most of the weight on the front tires I was glad that I had the tractor in 4 wheel drive and had a low enough gear to slow me down.
You will learn these things, either by discovering them the hard way or paying attention to details. I have found that being an older fellow, stopping and taking a break is a really good idea. Rushing to finish can lead to undesired results.
/ Our Tractor was delivered today #79
Yes, ballast is perhaps more important than HP in most cases. But the power you've got to the ground.
My ballast box is an old 3 point rear scoop, welded so it can’t dump and filled with rebar and concrete. Plenty of weight for my CK 27 Kioti with FEL. It has a small footprint and is easy to connect.
/ Our Tractor was delivered today #80
Yeah, ballast is a biggy. When I got my new LS-235 a couple of years ago after using my JD-770 for 20+ years I definitely cleared my sinus's when --testing-- the bucket. Had I not had my seat belt on I'm pretty sure I might have launched myself over the hood. The hyd's are like 3 times faster then that little JD.
By the way, congrats on the tractor, you have the re-newed tractor model. The old ones, 230, 235 and the 240 models where identical except for the power. From what I read LS updated/combined those models and now all the MT2 series are under the same umbrella. A lot easier to figure out what tractor is which series now.
I so like the new headlights, mine looks like a big spider is looking at you. They are bright tho.
2019 John Deere R-4038 (A61306)
2019 John Deere...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2019 Ford Transit 250 Cargo Van (A59230)
2019 Ford Transit...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
1997 LUFKIN 48X102 FLATBED TRAILER (A60736)
1997 LUFKIN 48X102...
