   / Share Pics of People Hauling or Towing Something Wrong #20,231
Really wasn't sure which thread to post this in but saw this earlier today...
   / Share Pics of People Hauling or Towing Something Wrong #20,232
A buddy of mine took this pic the other day in NW Indiana...
   / Share Pics of People Hauling or Towing Something Wrong #20,233
I've found using a palm sander works wonders - 80 grit. The palm sander has no effect on soft skin but readily reduces calluses; if there's a painful crack pretty much the only way I've found to deal with it is to reduce the callus around it because the flexing on either side of it will keep the crack going otherwise and by getting everything soft again it can heal.
It shouldn't need to be said but
Don't use a belt sander.
(I used to use a belt sander and it was super effective but unfortunately you do have to be very careful because it doesn't care if the skin is hard or soft)
I'll have to get some vaseline and give that a try; other lotions haven't seemed to help me much.
I use a dremel tool with the small drumb sanding attachment.
Takes the dry hard stuff off quickly and easy to handle and get into small areas.
Mine has a variable speed so you don't go too deep too fast.
Have to do it outside or somewhere you don't care about the dust.
First coat is Polysporin and then vasaline.
   / Share Pics of People Hauling or Towing Something Wrong #20,234
I retired in 2005, even though I was a crane operator and didn't work very hard I had calluses on my heels. For the next 12 years dried skin would peel off of my calluses. Worst part was when in the winter dry air they would crack. Very painful.
I tried some OTC medicines that didn't work. I happened to mention this to my neighbor and he brought me a sample of this cream called No Crack. I used it and in 1 or 2 days it was all healed. I've used it every winter for years.
My heels no longer crack, but once in a while I get a bad crack in my finger tip and use No Crack, which works wonders.
Edit: On my heel I would put it on a large square Band-aid. Also I bought my bottle online, but can't remember where.
   / Share Pics of People Hauling or Towing Something Wrong #20,235
For badly callused heels, I use these, with a battery powered drill. Work great, as long as the skin is real dry and you move around before you burn yourself.
   / Share Pics of People Hauling or Towing Something Wrong #20,237
...And his last mistake, I'm guessing...
   / Share Pics of People Hauling or Towing Something Wrong #20,239
Likely, but not certain death.
Here in the SF Bay region a trucker outran a river of burning gasoline when he crashed in a tunnel, years ago.
On TV I've seen firefighters outrun an explosion, keeping just in front of the fireball. They must just ride the shockwave. :ROFLMAO:
   / Share Pics of People Hauling or Towing Something Wrong #20,240
It’s hilarious when in a movie the “hero” outruns the blast from an explosion. Thats somewhere between 5000’ and 25000’ per second.
Must be wearing the right shoes.
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
CATERPILLAR M316C MOBILE EXCAVATOR (A52707)
CATERPILLAR M316C...
1994 International 3800 Bus (A55852)
1994 International...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
