Do any of y'all seal, wax or ceramic coat your tractor??
   / Do any of y'all seal, wax or ceramic coat your tractor?? #1
AirOpsMgr
Pike Co. Georgia
Kioti DK5310SE, Scag Cheetah II 72"
A thought occurred to me today when I was applying a DIY "Ceramic coat" to my car this morning, now I'm curious if any of y'all do any kind of paint protection on your tractors?
For those with older tractors and you don't see a need, I fully understand & no need to reply; But for those with newer tractors that feel there is an advantage to protect paint, make it easier to wash off the dirt and grime every few weeks, what have you done and does it make routine cleaning any easier?
In my case, I did a full detail on one of our cars using many steps and got to thinking that maybe I should try to do something to the paint on my Kioti that's coming up on 2 yrs old ... Couldn't care less about shine and such, but does it help with wash downs? If my tractor is super dirty, I'll hit it with a car foam cannon and then just pressure wash it, always gets most of the dirt and grime off.
In my car's case, 2nd owner with over 52K miles, drive it weekly and not a "garage queen" paint job by any means, so it was a full wash, iron decontamination, clay bar, then get out the buffer to do swirl remover and apply a polish, then prep the surface with Isopropyl alcohol and apply 2 coats of Meguiars M888 "beyond ceramic" coating, way more than I'd do for the tractor, lol
While I'd never go to that level of paint correction on my tractor, I do wonder if a good wash / decon / ceramic coat would be worthwhile to keep the paint looking decent on a 2 yr old tractor and making washes easier / faster for years to come? Keep paint from fading just a little while longer? Or, will applying something like a "ceramic coat" just get beat to hell and wear off too quickly (considering grease, oil, etc) to make a difference in the long run?
Pics below of the car detail, and I certainly wouldn't need such a finish on the tractor, but if a ceramic coat helps preserve the paint, I might consider spending some time applying it to the tractor as I have lots of product left over....
Constructive thoughts / comments? (and yes, I'm well aware it's a tractor, it is & will continue to be beat up), but simply curious if others have applied any type of protection and seen a noticeable long-wearing difference when washing off the day's or week's grime, prevent fading, etc??
Thanks all & best regards,
Greg
   / Do any of y'all seal, wax or ceramic coat your tractor?? #3
I read a post by someone on another tractor forum who said that he washed his tractor with a cup of wd-40 in five gallons of water. He claimed that it protects paint, rubber, and decals and keeps it looking new.
I'm guilty of not washing for several months at a time, usually it comes when I can't tell there's supposed to be orange paint under the dirt and grime, that's when it gets a wash, lol!
Just curious if doing a protectant helps speed up the wash process. Never heard of WD-40 for a coating, I wonder if the residuals would cause additional build up
   / Do any of y'all seal, wax or ceramic coat your tractor?? #5
The guy that posted that said that they also treated aircraft with that wash treatment.
   / Do any of y'all seal, wax or ceramic coat your tractor?? #6
Here’s a copy and paste from the other forum. He actually uses three cups per 5 gallons.
“No soap. 3 cups WD40 in a 5-gal bucket….forcefully add water…used for soap/detergent. It dissolves grease, and leaves a “chamois” finish that water beads-up and runs off. Lubricates rubber weatherstripping and gets into crevices, lubricates hinges/latches and prevents rust. (This is an old “Hints from Heloise” trick…only she recommended kerosene in water instead of WD40 for car wash. I use this same formula on my never-polished in over 20+ -years, 1953 airplane instead of soap (which dulls aluminum.) Blah! No Soap!)”
Yup, I've been in the aviation industry for a while & have heard that debated many times for many applications. I do my best to stay out of those conversations as it usually leads to a socket wrench being thrown and someone shouting "You youngins don't know a G D thing when it comes to wrenchin on a G D aircraft!!!" .... so as soon as the conversation gets to that point, I walk the other way and keep my trap shut!
Interesting, never have heard the old timers bringing it up as a final coat, they always talked about degreasing and prepping with it, using it on propellers, on hoses, etc ... maybe I'll ask some of the old timers at the job (as long as there's no socket wrenches nearby that they can throw at me), lol
   / Do any of y'all seal, wax or ceramic coat your tractor?? #9
Please report back what they say.
   / Do any of y'all seal, wax or ceramic coat your tractor?? #10
No it’s a tractor it’s gonna get real dirty real fast. As I get older I meticulously cleaning cars isn’t really on my list of priorities anymore. My 69 charger and hellcat challenger are garage kept but I couldn’t even tell you the last time I properly cleaned them.
17501-FL (A56857)
17501-FL (A56857)
159115 (A60430)
159115 (A60430)
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2019 KOMATSU PC490LC-11 EXCAVATOR (A60429)
2019 KOMATSU...
