LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 13,981
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Yes, she has many nice videos.this young couple are farming and videoing like mad.
She is very articulate and just believable.
Having planted row crops and waited for them to come up,
when "that first hint of green" is seen, like I saw today driving through
Solebury looking at the fields. The first of the corn was popping up.
Other fields still beige or brown, likely from Roundup waiting for Roundup ready beans or ethanol corn.
these folks pretty much represent the best of American values
they are dealing with flooded fields and tornadoes and they saw the Northern Lights which apparently futzed up some gps units.
oh to be young and be able to afford to do this.
if you don't inherit land, it's pretty tough to do if you actually want to make a profit.
If you don't care, and many don't, they just like the farm life, the tax deduction, the seasonal quality of life in general.
I bet Don is still discovering new stuff in his new house.
And all that redecorating to do, his wife will be busy.
David, not sure you have any other alternative but you have been remarkably patient.
Did they pressure test the fuel line, could a glob of gasket guck be clogging a line?
had that happen on an Olds Bravada; pick up tube in transfer case clogged from the beginning build.
From a customer relations standpoint, If I were LS, I'd be giving you a loaner on them. 2 months is simply an unacceptable amount of time for
a new tractor to be down. They should be flying a tech in, whatever it takes.
Thank goodness your wife has a tractor.
It appears your local guy just doesn't have the diagnostic aptitude you need.
at some point you have to start replacing lines, parts, something...
I think your aux fuel tank makes sense. Will eliminate the tank. Then you have to trace the lines forward, blow them out.
good luck
cleaning and testing your fuel injector is another good one to cross off the list.
would be nice if someone here in the LS threads could help you. I'm just lamely guessing
Many of the high tech operations had issues with GPS enabled systems.
Just think of the disaster it would have been if these so called autonomous trucks were on the highways or autonomous tractors with highend expensive equipment out running around when that happened.
