   / Your last generator Maintenance Run #6,672
Dang !
Not sure what put more drool on my keyboard.... the Deal on the trailer, or your Pull-Toy !
(y)(y)(y)
Rgds, D.
Yes, that trailer was quite a score as well.
That whole setup is heavy. The old deuce didn’t like pulling it up the hills very much!
It’s a Mack E7, 360HP. Made in 1999, no emissions and is mechanically injected.
I'm going to assume it's already in your Will..... might outlast all of us, put-together !
If you have a minute, post-up how your test-run went.
Rgds, D.
   / Your last generator Maintenance Run #6,674
Finally found a suitable back up power source for my machine shop. A local municipal agency sent this to auction and I picked it up for what I feel was a steal. 325KW, 3 phase. Total hours are just under 600.
We are right in the middle of forest fire country, so the planned outages are happening more and more. A few days without power really impacts us and our customers.
It’s supposed to rain like crazy this weekend, so I plan on getting this serviced and put thru some load testing.
All that power and look at the air compressor next to the tire!
   / Your last generator Maintenance Run #6,675
Very nice but 325kw / 360hp doesn’t add up!
90cummins
It's 120% efficient!
90 carries those #'s better in his head than I do.... but I was initially thinking Peak Pwr, when I saw his comment....
Rgds, D.
   / Your last generator Maintenance Run #6,678
90cummins
Here are the tags from the engine and generator head. I'm only able to go with those #'s until I can somehow load test.
   / Your last generator Maintenance Run #6,679
Rgds, D.
It does seem likely it's 325KVA, which would bring it to about 260KW using a .8PF if I'm doing the math right?
Thanks for the pics OR ! We like pictures.....
I'd have to start by looking up "Base Rate", as I don't play at these power levels..... poked around a bit just now.... not sure if that term is in current (pun-intended) use..... might have to wait for one of the Commercial guys like CM to drift by for a historical perspective......
W/O a calculator, you math looks about right.....
(from when I went looking,.... a cold-start on a 500 KVA.... don't show this to your Sierra Club friends !)
https://electrical-engineering-portal.com/important-generator-set-rating-considerations
Rgds, D.
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
generator (A56857)
generator (A56857)
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
Generac XG8000E Generator (A55973)
Generac XG8000E...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
2003 International 9200I (A53317)
2003 International...
