What to do about this crud on hydraulic hoses?
   / What to do about this crud on hydraulic hoses? #1
jymbee
Upstate, NY
Massey 1652, 1949 Farmall H
This crud (algae? mold?) Has been slowly building up and I've been putting off doing something about it. But coming back from several months away this Spring, its gotten significantly worse with more build up. Time to try and remove it. Any suggestions?
   / What to do about this crud on hydraulic hoses? #3
Park it in the barn and you won't see that.
   / What to do about this crud on hydraulic hoses? #5
I would suggest applying "Wet & Forget" algae and lichen cleaner on a dry day when there is a forecast of a dry day or two afterwards. A week or two later, hose it off or use pressure washer. If you use a pressure washer, I would use a 25 degree nozzle, and don't get the nozzle too close to avoid damaging the hydraulic hoses.
All the best,
Peter
   / What to do about this crud on hydraulic hoses? #6
All the best,
Peter
Typicaly all that outdoor cleaner stuff is just a strong bleach. You can also find it in the pool section called "chlorinating liquid"..for about 1/4 the cost.
   / What to do about this crud on hydraulic hoses? #7
Wipe off what you can and spray with vinegar, then pressure wash.
   / What to do about this crud on hydraulic hoses? #8
Pressure washers scare me. I've seen a lot of damage from them!!!
There are three levels of bleach at the box stores to chose from. Laundry bleach is the safest, and the weakest. Outdoor cleaning bleach has a green label and it's twice as strong. I'd probably start with that. Lowes and Home Depot have it in their cleaning section.
If that doesn't work, and what I use for black mold is Swimming Pool Shock. Inside a house, it will make your eyes water, but it will also kill everything growing in there, and bleach all the lumber clean.
Be careful not to get any of it on your clothes, they will be ruined in seconds!!!
   / What to do about this crud on hydraulic hoses? #9
Wet & Forget has no bleach, and the active ingredient is pretty benign, which is why I suggested it. Basically, it is a detergent with specific efficacy at disrupting lichen and algae cell membranes.
Here is the MSDS;
If you value your hydraulic hoses, you never want to use chlorine on hydraulic hose rubber. It isn't formulated for bleach resistance, unless you have really pricey hoses (CPE, PTFE, Hypalon)
If you want to use chlorine compounds (hypochlorite) to bleach your brick, or concrete, that is a different story, although I personally prefer TSP, or its relatives.
All the best,
Peter
   / What to do about this crud on hydraulic hoses? #10
a pressure washer set with a wide spray pattern is my go to cleaning device. i agree a tight pattern can eat thru alot.
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
