M62 TLB for Maintaining Hilly Land ?
   / M62 TLB for Maintaining Hilly Land ? #1
AuCivil
Alabama
JD4710
I bought some land for an investment, hunting and as a retirement piddle project. I've got 215 acres of land that's 50% moderately sloped thinned pines and 50% steeper sloped hardwoods and hardwood bottoms. I need to maintain the existing roads/trails and create/improve others so I can access the the rest of the property by SxS. I don't want (nor can I afford) a fleet of used vehicles that may or may not need constant repairs. I don't have enough years left to spend it working on equipment. Would prefer to buy new with extended warranty so someone else is responsible for repairs.
I'll be putting in a septic system, waterline, building pad, maintaining/building access roads, food plots and some brush hogging. Was considering a M62 since it appears to be muli-use piece of equipment. I am concerned about stability driving up and down some of the access areas with the M62 TLB. The worst current road is in the range of 36% to 40% (19 to 21 degrees). I can go up and down with my JD 4710 with loaded R4's but I have also slid down too. The M62's additional weight and the backhoe weight concern me. Don't want to flip over.
Stability on the side hills worries me too. Those areas can be more in the 25% (15 degrees) range. Will the M62 be more tippy than the JD 4710? How does the backhoe affect the tippyness?
   / M62 TLB for Maintaining Hilly Land ? #3
The backhoe on an M62 is no small toy! Lotta weight up in the air for sure. Might be more tippy than a 4710, dunno.
Overall I would say its a good fit for your property and projects - just don't drive it on crazy slopes, lol. But seriously, its the exact right machine to fix your trails and make them more safely navigable. No reason to be driving up 40% slopes - cut a bench trail to reduce the angle.
   / M62 TLB for Maintaining Hilly Land ? #4
Not advising anyone to do it but we've got a spot on a hill. Maybe 20 years ago I needed to get there to dig a flower, hide a dead body, I don't recall.
Bottom line, I did NOT feel comfortable "just driving" over to it (full sized backhoe/loader)
I put her into low gear. Lowered the downhill stabilizer to help catch a side roll then, took the backhoe. I extended it ALL the way out, as close to the ground as I could get it but, I moved it perpendicular so it was now facing up the hill as a counter weight.
I was puckered the entire time but got what I needed to do (forget) done and have never been back on that hill.
   / M62 TLB for Maintaining Hilly Land ? #5
We have a Kubota M59 TLB, which is the M62 predecessor with a slighly shorter BH boom.
Yes, the Kubota TLBs are noticablly more stable on hills than a tractor because they weigh twice as much and because a lot of the weight is low down due to heavier duty construction.
You can also add rear wheel weights and spacers.
But with that many acres, and considering the price range you are already looking into I would recommend a full size TLB. Something like a low hour Deere 310G - actually any model 310 from the older E to the newest ones would be more stable than the Kubota. And they are comfortable, too. The JD310 stability and durability is in a whole different league from homeowner TLBs like the Kubota. I know that for a fact as we live in the mountains and have both.
Stop by your yellow (commercial) Deere shop and try one out.
Our 310 has a buddy seat plus room for the dog when we drive it to town.
Whatever you get, get it with a thumb. I try to go straight up and down hills. When I have to traverse a hillside I pick up a log with the hoe+thumb and swing it alongside the uphill side of the tractor as a counterweight. It helps a little with the pucker factor. Better yet, get a dozer to make you some roads.
There will still be plenty of work for the TLB after the dozer leaves.
rScotty
   / M62 TLB for Maintaining Hilly Land ? #6
Interesting inquiry: 215 acres is a bunch. First you are going to need 3pt hitch hardware for sure besides just the backhoe. You know that... I have no experience with the backhoe but like anything on steep ground -- keep the weight as low as you can.
The typical problem with Kubota is that the Japanese have never so far realized what steep ground is or why one needs the rear wheels far apart. As a result they do not give you much latitude for spreading your rear wheels apart. That is certainly true of the medium to smaller Kubotas -- you need to investigate on your own if you are buying an M62. I do operate other things (e.g. a MF2660 and Kubota B2150) a lot on steeper ground than you mentioned. I have measured one slope that I cut on a monthly basis (and have for years) at 45% in the worst spots. There is NO TIPPINESS in either of my tractors on that slope going sideways at all. Going up/down I do well on 50% slopes or a little worse unless the ground is muddy. Very comfy and plenty of safe margin. That said my older Kubota is fitted with 6" spacers on both sides. It was NOT safe before the spacers. The MF2660 has rear tires 8ft apart at outer edges and they would go wider BUT would create trailering problems and do not need them wider anyway. If I were you, I'd measure the rear tire spacing (I hope the M62 gives you choices!) and set them out as wide as you can. If it feels at all marginal, add spacers ! They do make a world of difference. Only need spacers on rear, not front.
I had a JD4700 for 10 years and it was very stable on the 45% slope and steeper. Anything steeper was places where I was letting the tractor down over it with the brakes while bush hogging (or climbing it upward if the soil allowed, depending on seasons.)
Aside from the roads, how steep do your bush hogging areas get? I used a 6ft Deere MX6 and that JD 4700 on some VERY steep ground and it was a reliable and very controllable machine. Served me well.
One thing you are in for is the pain and strain of taking the backhoe on and off and switching to the bush hog. I do not envy you there with the weight and awkward shape/size of the backhoe. I'd go visit someone who owns that configuration and study that a bit if I were you. Might get the dealer to demo the swapping I would think. Obviously it can be done but as you said , we ain't getting younger.
rScotty
Thanks for the advice. No doubt it would be better but the 310 weighs too much for me to move with my setup. It also doesn't have a 3-point/PTO option. If I could avoid limbs, the cab would be nice.
The areas that need to be mowed are flatter. Youtube videos seem to indicate that changing the 3-point to BH is not overly difficult.
   / M62 TLB for Maintaining Hilly Land ? #9
As JWR says, the Japanese don't seem to understand about widening the tractor wheelbase for hillside work. But American farm tractors do.
There is a 3pt kit for the M59/62. I'd get it if you go that way, but swapping the hoe and 3pt is enough of a chore that you may want to keep your eyes open for an extra 3pt tractor.... an older American farm tractor for the 3pt hillside work. Although compact and utility size tractors don't have much ability to widen their stance, the next size up in the tractor world are those farm or ag tractors and many offer adjustable width of the wheelbase.
Our old JD "B" ag tractor isn't much good for anything except 3pt work, but like most farm tractors it came with long rear and front axles. The tires can be extended out along those axles to nearly ten feet total. That makes it almost as wide as it is long, looks ridiculous, but is almost impossible to flip. You can find ag tractors with extra long and wide axles.
My own view about hillsides is I try every way possible to avoid going there.
Both of our TLBs will will slide sideways before it begins to feel tippy. I don't know why that is so, but am very glad it does. Both have wide construction tread tires with heavy sidewalls. The M59 weighs a bit over 8000 lbs, the JD 310 about twice that.
Note that most American and Japanese tractors and TLBs DO NOT have brakes on the front wheels or any suspension - although I understand that European tractors have both. Think for a moment about what that means when going downhill with a weight in the loader bucket.....
rScotty
   / M62 TLB for Maintaining Hilly Land ? #10
Which is why you always, always use 4WD for working on hills.
2013 Chevrolet Silverado 3500HD 4x4 Crew Cab Flatbed Truck (A55973)
2013 Chevrolet...
Caterpillar 725 Off-Road Dump Truck (A57453)
Caterpillar 725...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
1994 International 3800 Bus (A54814)
1994 International...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
