You Know You Are Old When
   / You Know You Are Old When #702
Great thread! Can't believe I just found it.
Getting old is:
1. Having to pee, while you're peeing.
2. Sitting on the toilet, and having your nuts hit the water.
And on that subject...
I did that in grade school!
Speaking of nuts for me it started about 10 years ago (early 60s?) tie my shoes I thought someone kicked me there! When I have to pee it's like R I G H T N O W...only to have a 1/16" stream and 5-10 minutes!
As a teen it was like a garden hose & 20 seconds!
   / You Know You Are Old When #703
Take some prostate supplements - fixed it for me (y)
The worst was the dribble after peeing 😣
The urgent need and the dribble all gone now. Phew
   / You Know You Are Old When #704
I had the surgery for that... it took me 10 years and 3 doctors, and by then I really needed to do something. I was passing blood clots and the first doctor told me it was "concentrated urine."
   / You Know You Are Old When #706
My first radio was a crystal set with a long wire antenna run out my bedroom window.
Me too... still have the wire out the window at moms place and the CB antennae on the roof...
Childhood memories... built a radio room in the attic... Perfect size for a 10 year old.
   / You Know You Are Old When #708
See a doctor about it. While it could be signs of prostate cancer, it could also just be an enlarged prostate, squeezing the life out of your tubing. I take two medications for that. Everything works great now.
But best to get it checked if you already haven't.
   / You Know You Are Old When #709
I had the rotorooter procedure (called turp, sp?) done about 15 years ago for the gotta go NOW and the need to go every 10-15 minutes. It was an enlarged prostate and for awhile after the surgery all was good but for the last several years I have reverted back to the NOW and OFTEN. Doc says everything checks out and cannot understand why it is happening. Tried every drug prescribed for (and some not) the frequent need to urinate and some OTC supplements, nothing has helped. It doesn't help that I am prone to kidney stones and must drink often but still I have many times urinated, walked to the mailbox (50 yards) and have to go again. If I need to go to town I make sure not to drink anything for a few hours prior to leaving which aggravates the kidney gravel pit.
I have decided I must have a tea cup bladder.
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
Trailer (A56858)
Trailer (A56858)
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
4 CYL ENGINE BLOCK & ENG STAND (A58374)
4 CYL ENGINE BLOCK...
40 Dry Van Enclosed Trailer (A57453)
40 Dry Van...
