What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #881
On foreign cars? I’ve never seen any on any car.
I guess it depends, definitely took the guess work out of breaking stuff and made my job easier 15 yrs ago. My current foreign compact beater doesn't have one but does have secure places to hook on underneath.
   / What is some of your Pet Peeve's #882
On the wifes BMW , little squares on front/rear bumper and a hook in the trunk toolbox.
   / What is some of your Pet Peeve's #883
And on smaller unibodies a small plastic cover over a threaded steel hole on your bumper, to screw in a eye bolt usually stored with the spare, anyways folks should make sure it's used to pull your car out of a ditch instead of hooking a winch to more fragile under built A and control arms. From my experiences.
Don't think I've ever seen that, but so few new cars today have an easily accessible place to attach a tow strap that won't cause damage. Not sure I'd want to try pulling on a bumper on a modern vehicle though.
If the battery is dead can you still put the car in neutral to roll it?
No idea. Never had to do it.
   / What is some of your Pet Peeve's #884
. To get out of a truck in the middle of winter or other questionable traction
area's to lock the hubs was a bit of a peeve of mine
I can say from almost 8 yrs of driving a gm truck I've never once had a problem with the transfer case or the auto hubs locking,
When I had locking hubs they were in much of the winter, unless I was doing a lot of highway driving. Yet that was a completely different system than what most vehicles have now. The latter have CV shafts rather than drive shafts in the front end which are always turning. True off readers don't like them because often the differential is lower than the cv shafts.
   / What is some of your Pet Peeve's #885
I have a number of these towing eyes from all the Volvos I have, They also fit my 2014 CTS-V coupe.
   / What is some of your Pet Peeve's #886
Yeah, it was a European standard dating back probably 30 years. I've always noticed them on all of our European cars. Not consistently found on American cars, though.
   / What is some of your Pet Peeve's #887
I was like that with manually locking hubs until I finally got a truck that wasn't.
I much prefer manual hubs. It's usually relatively easy to predict when it'd be nice to have them locked in advance.
After all, leaving them locked is no worse than on vehicles that didn't have any kind of locking hubs or CAD setup.
And speaking of CAD, since the manufacturers don't mind that the spider gears are getting one heck of a workout when one axle shaft is disconnected, I've adopted a similar strategy with my M1008 (a live axle GM 1-ton, basically).
Being lazy, I leave the right hub locked, allowing 2WD LO, then it's only three steps to lock the left one when I need 4WD.
   / What is some of your Pet Peeve's #888
I ordered my truck in 1990 with manual hubs because I'd heard that some auto hubs were unreliable. I've had to replace one hub years ago and don't know of anybody that had replaced any auto hubs. So sometimes progress isn't bad?????
   / What is some of your Pet Peeve's #889
I've got stuck a few times due to auto hubs not engaging until the rear tires had turned enough to make them engage...at which point it was too late.
To me, auto hubs are like rain sensitive wipers. If I can't perform the simple task of locking the hubs, or can't tell when it's raining, I have no business driving.
Okay, if I end up in a wheelchair and have hand controls in the vehicle, auto hubs or CAD may be acceptable. But then I'd prefer no axle disconnects whatsoever since fixing the problem would be tricky at that point.
   / What is some of your Pet Peeve's #890
We give detailed last mile instruction for haulers to reach the farm but most use GPS and few listen.
Any normal vehicle and trucks no problem with GPS...
Problem is when a conventional with a 45' trailer takes the GPS route it's not possible to make the last turn so they have to blindly back out to the county road and all traffic stops plus every year some driver with limited comprehension takes out a street sign or neighboring mailboxes...
Why professional drivers would rely on a computer over actual onsite direction is beyond me.
Google didn't even acknowledge that this place existed. I entered the location on their edit page. Then they acknowledged that there is a house here but gave directions to use Pilot road below the house. Now, they finally have the directions mostly right, except they try to route people through a neighbor's driveway and pasture and up a 15% gravel grade, instead of the actual road, Warn, which is about 100 yards further up the county road. Like you I have to include directions not to follow Google maps phone app instructions. However, they depend on a GPS device or Google.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
1789 (A58375)
1789 (A58375)
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
Wells Cargo Express Wagon 24' Enclosed Trailer (A55272)
Wells Cargo...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
