Good morning!!!!
   / Good morning!!!! #181,714
thanks David.
nice to leave rv with everything put away and bathroom all shiny and clean.
interestingly the bidet seat is tall enough to cover over everything. Never know
I tore it a new one...
ok guys, here is your new Kubota tractor present, hot off the press.
how can you resist?...
   / Good morning!!!! #181,716
39 going to 58. Hoping for sunshine. Stayed damp all day yesterday.
Saw the son and family off after a nice breakfast and pour overs for everyone. Quiet now.
Found videos and photos of two thru-hikers that passed through the 11,000 acre wildfire area, now that the AT is reopened. Looks in much better shape than I thought. Also read the forest service preliminary report. Seems the wind pushed the fire so fast it only had time to burn off the leaves and ground clutter in that area. Hoping most trees will likely survive. Will ultimately make for a much healthier forest.
Pine trees down here did not survive similar situation.
good progress made
toilet back in place, simple clamp hookup, doubled up, with enough slack to pull the toilet out next time to work on it.
not going to test it, system drained
going back out after lunch to caulk around the edges
Drew, I hope it holds. PITA to test.
   / Good morning!!!! #181,717
thanks David.
Omg they are pricey for plastic bits :oops: Makes me want to make some. 2 ft of PVC pipe and a couple of screw in end caps ;)
   / Good morning!!!! #181,718
The appointment with the cardio specialist Dr went well. He said you must be eating something right because both of your numbers are good. To wife he said you are not even in the pre diabetic range which is unusual these days given your age. Next appointment in a year.
Outstanding!!!! (y)
   / Good morning!!!! #181,720
33F cloudy.
Snow removal went better than I thought it would and rear blade on Kubota (y) but with ground not being frozen I'll have extra lawn raking come spring. :(
While cleaning roofs shoveling walks weight of snow on the limbs/branches did lot pruning :eek: but never lost power as many have.
Plans for the evening...after dinner nest into recliner watch MNF until eye lids get heavy.
Enjoy your evening all.
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
SKLP Pipe Crimping Machine (A57149)
SKLP Pipe Crimping...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
