XR 4046 HC Diagnostic adapter
   / XR 4046 HC Diagnostic adapter #1
Camoconcepts17
LS XR4046 HC
Looking for an diagnostic adapter for the XR 4046 HC.....it is rectangular and a scan tool with an OBDII will not plug in.....any one have any direction that i can look?
   / XR 4046 HC Diagnostic adapter #3
Here's the adapter
Here's another link to diagnostics
Thanks for the quick reply's.......I have a Nexlink diesel scan tool with almost every adapter that there is, except the one in this pic.....apparently the 4046 has a unique port, see pic attached. Pic is at an odd angle but it is a rectangle and not a trapezoid shape. It looks to be an 8 pin?
  • LS XR 4046 H Diagnostic Connection Port.pdf
This is a slightly simpler tool than the Nexas that I own. This link shows that they have the unit for a 4046 in the draw down bar but when I called them a couple weeks ago to ask about the connection issue they confirmed that they do not actually have one for the 4046.
   / XR 4046 HC Diagnostic adapter #6
Is that port you pictured located under the dash on the right side?
Yes it is....I took this pic from a different post but my tractor is the same.
   / XR 4046 HC Diagnostic adapter #9
I tried to order the LS scan tool but my order was cancelled due to a problem with the tractor's diagnostic connector not being able to connect to scan tool. My connector is the same as yours.
   / XR 4046 HC Diagnostic adapter #10
Hi everyone. I've had a XR4046 for several years now but it's acting up. I too have the same 8 pin (6 active) pigtail on the right lower part of my dash. It took a lot of research and a little luck but I picked up the part today. LS part 40268283 CONNECTOR-DIAGNOSIS (ISO)-TR. I couldn't find this on the LS website part finder but you can order it. It will convert the 8 pin adapter to the round 9 pin diagnostic port for the diesel code readers. I paid around $94. I plan to test it tomorrow.
UNUSED FUTURE FT-SSJ430J JAW CRUSHER (A57192)
UNUSED FUTURE...
2013 Heartland Elkridge 37UL 37ft. T/A 5th Wheel Travel Trailer (A55853)
2013 Heartland...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A57192)
UNUSED SDLANCH...
1986 Hobbs Cone Star 35' Dump Trailer (A56469)
1986 Hobbs Cone...
