Turned up he fuel in my L39
   / Turned up he fuel in my L39 #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Turned up he fuel in my L39 about 2 months ago.
It was pretty easy once I removed the anti tamper sleeve on the fuel adjustment screw on the fuel pump. As it is not a turbo and I do not want to roll coal or spike the EGT, I kept it sane to where I see a hint of grey smoke and called it a day.
Tested by running up a hill, same day, fully warmed up.
Stock best speed was 5.1 to 5.2 MPH,
Turned up 5.6 MPH.
Note 2700 RPM is 6.5 MPH in 10th gear, so I was testing near peak power. I can definitely feel the torque increase, though modest.
May not be much but that is going from 37.2 HP net to 41hp.
As I have the L39 ballasted ot over 8,000 lbs, it sure help, still a slow dog, but I think way better.
   / Turned up he fuel in my L39 #2
Okay, pardon my ignorance here. So you turned up the fuel. Can you explain just what did you adjust that had a tamper proof cover? This is where? on the injection pump? On the throttle control? On the governor?
   / Turned up he fuel in my L39 #3
I'm curious about the details of exactly how he did that too. It would apply to most of the pre-emissions tractors. BTW, I sure do like those L39 TLBs. A real nice size & wish they still were on the market.
Just musing now.... Since diesels are normally set up to operate way out on the lean side of the stoichiometric ratio, adding more fuel not only richens the mixture, but brings it closer to the max power point - max power being closer to where complete combustion takes place.
Of course max power is also max heat, but it sounds like he is doing it conservatively.
rScotty
   / Turned up he fuel in my L39 #4
Congrats on the fuel mod.
Please….Monitor your EGT’s. Do not tune your tractor/engine by sight alone. Most folks are shocked when they learn the temps they’re running after a simple fuel mod when there’s a heavy load on the engine, especially if you’re operating your tractor above sea level.
Mike
   / Turned up he fuel in my L39 #5
I could be wrong here, but I don't think he's in the danger zone just yet. I suspect that what he did was turn the high idle up a bit. Maybe he will come back and explain it a bit more.
rScotty
A late model L45 is the best without DEF, if you can find one. It and the L39 will outwork most utility tractors doing dirt work. Really.
Look at the fuel pump, Towards the front end of the tractor there is a metal sleeve covering whats looks like a stud. Its crimped om well so good luck taking it off. I used a Dremel an sone tiny pry bars so I could reinstall the mangled sleeve. Underneath there is a adjusting screw and lock nut.
In stock configuration, find a long grade and run up at full throttle in whatever gear gets you at as close to 2700 RPM as possible.
Turn screw out 1/4 Turn and retest. Keep repeating and adding fuel till you see a bit of grey smoke, then quit while you're ahead. If a turbo, definitely install an EGT meter on the exhaust manifold. 1200F after several minutes at full throttle should get max temperature. Temp you should see. A NA motor is hard to hurt, as you can only add so much fuel before rolling coal. Other than plowing snow, My engine load on the L39 is never at the max for long, so I don't worry. I will install an EGT, just out of curiosity. I have never used the PTO or removed the Backhoe. I use the Mahindra for PTO work.
There are a few relatively easy grades that I would have to pull in 10th gear in stock setting. Now adjusted, at least with a head of steam and unloaded, I can pull in 11th gear. Much more satisfying.
Funny how Tractor manufacture's sell the same tractors, with same motor, but different power rating for more money.
   / Turned up he fuel in my L39 #7
Any photos of the mystery screw?
Tore my rotator cuff 2 days ago, otherwise I would go out and take picture. Spending day resting and one armed.
   / Turned up he fuel in my L39 #9
Never mind about the photo. I see the screw you meant.
Just relax and recuperate.
  • Kubota Tractor Model L39TL PARTS_MANUAL pgs 34 & 35.pdf
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2015 FREIGHTLINER M2 24FT BOX TRUCK (A56138)
2015 FREIGHTLINER...
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
