Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,412
These aren't any guarantee for sideways stability on uneven iced terrain.
They are mostly for back and forward traction.
The ice cleat? I have them on my harvester tracks they really don’t let you slide sideways, it’s not like a single bar grouser it’s much less surface area to try and dig into the ice.
   / Tractors and wood! Show your pics #22,413
I don't know what a tracked harvester uses as track configuration. I do know a tracked harvester is articulated and with two set points which allows it to adjust better to terrain.
A stupid bulldozer is all one piece and adjusts poorly on uneven iced terrain.
Trust me, you do not want to be on an iced and slushed side hill with a dozer cleats or not.
Two welded half inch thick pieces of metal on a grouser is not going to stop a 20,000 lb dozer from going sideways once it starts to slide.
The dozer my boss rented was set up for winter logging and it still went sideways.
There are a lot of deciduous trees in the North East and the leaves that fall to the ground act like sponge supports for a dozer.
You can't get a cleat far enough into solid ground as a result because a dozer is really exerting minimal poundage of ground contact.. Add ice and snow to the picture on top of this stuff and as it gets past 32* in temperature, you have what acts like ball bearings.
The dozer, as a piece of winter logging equipment was an experiment on my companies part that failed miserably on several fronts.
   / Tractors and wood! Show your pics #22,414
Thanks for the comments all ! For me having tractor roads in the woods makes all the difference in being able to work in and get around in my wood lot. I keep the tractor on the roads and out of the slash so the lack of a belly pan and forestry tires are not issues so much and I can access wood in large hilly terrain areas much more safely.
Arrow, I remember well, and am still puckered, from the first and only time I tried to scarify our road with the dozer tracks after a bad ice storm.
gg
Gordon, great pictures and story! I'd love to have a little dozer but I'm afraid of the trouble I would surely get into with it! When we bought this place I had a couple openings clearcut in the woods and a road running all the way round the place by a big local logging company (big business here) so I have tractor access to most of the place. I only cut enough trees for firewood and lumber for myself and I mostly just work around the outsides of these little clearcuts and it all works for me. I do love watching your adventures however. Very nice looking woods by the way!
   / Tractors and wood! Show your pics #22,415
So, had a couple hrs free the past few days & we have been working on a cut & spilt area... trying to have something close to the house but not have the mess in the yard. Created a drive thru area where we can bring the logs, cut to length, & split without making a mess in the yard & still being close to the house.
And had some time to finally pull some weathered downed red oak that has been down for a couple of years (thankfully not resting on the ground)... 2023-10-11 16.24.33.jpg
Off to the Shed...
   / Tractors and wood! Show your pics #22,417
I saw this on a local CG add:
**LOOSE FILL ONLY to TOP OF STANDARD BED RAIL (not to exceed 22.5"H). NO STACKING WOOD - Wood will be tossed into your truck or trailer bed, ONLY.
   / Tractors and wood! Show your pics #22,418
How are they selling it - by the cord from pre stacked piles on the ground and that is just their loading method or by the truck load w/o a size stated ????
gg
   / Tractors and wood! Show your pics #22,419
gg
In some states, selling by any other measure than by the cord (e.g. "pickup truck load" or "pile") is illegal. Though if it's between a willing seller and a willing buyer, I'm not sure who would lodge a complaint that would kick off enforcement action (assuming that the volume has not been misrepresented.
   / Tractors and wood! Show your pics #22,420
In Illinois there is no standard measurement requirement, or if there is, it’s completely ignored.
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Non running toro mower (A48082)
Non running toro...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
