Just arrived and hour meter is broken
   / Just arrived and hour meter is broken #101
The hour meter is one small component of the overall tractor. If you are putting that much effort into the hour meter, ask yourself if it is because you are assigning too much importance to that meter.
Just looking at a tractor closely and listening to it run and work will tell you far more than the hour meter about the future of the tractor. . Last tractor I bought had almost 6000 hrs on the clock. It's worked well for ten years now. I just helped get some hay in using a friends IH with 2500 hours on the clock and that tractor is old and used up in every direction.
rScotty
   / Just arrived and hour meter is broken #102
Ouch. This should be a case study on why buying used isn't always the better idea...there's a thread for that.
If you were more local to dealership, they may be more willing to work with you on a resolution. The bad press would be worse for them than a lawsuit.
I feel your pain, OP. In a fair world, they would take it back and pay shipping one way. You'd still be out the $1100.
   / Just arrived and hour meter is broken #103
rScotty
It is not the meter, per se, that is at issue. The tractor was priced as if it was 1500 hours, not 6000 or ? Whether the tractor will work going forward is a crapshoot. If the dealer didn't correct something simple like this, what else is wrong that he cannot see?
   / Just arrived and hour meter is broken #104
The dealer didn’t make any claims of fixing anything. That’s why it’s a 2006 used tractor for 1/3 the cost of a new shiny one. Maybe the tractor is a little rougher than the op envisioned. All of which could have been avoided had he actually looked at the tractor. But the tractor is currently working as advertised which would make any claims of being scammed pretty hard to convince on a judge. The OP ultimately failed to inspect his purchase and now he’s trying to make someone else eat the cost of his dissatisfaction.
This here is the exact issue.
If the price per hour is calculated at 6000 hours instead of 1555, the deal becomes poor/bad.
However, I spoke to the dealer just now. They called the guy that owned the tractor and spoke with him. He said he's been keeping track and said it was right at 2000 hours.
The dealer apologized for not seeing the hour and for miscommunication in the ad and with me. I told them I wasn't trying to be a d!ck, but Im not able to trust him as much as they are. I said the issue is if he didn't track it well or it's a guess, there could be 4000 or 5000 hours or more. I said there's no way of telling and that puts all the liability on me as the hours are not correct.
The dealer agreed and we spoke about options. I said I'm OK keeping the tractor at 2000 hours, but I'm concerned that if it's more and I'm way closer to major maintence, that burden should be shared due to the "miscommunication" of the hours and me already buying into the issue.
He agreed and they are discussing the solution and will call me in a day or two.
   / Just arrived and hour meter is broken #106
My dealer has equipment that’s basically scrap on their used lot or as I call it the boneyard and they have basically new equipment that only has a few hours on it and everything in between. Thinking every piece out there is going to be in perfect working order just because a dealer owns it is insanity. I bought my mini x, a skid steer, and a backhoe from them used. I don’t remember if I demoed the skid steer or not but they allowed me to haul the mini x and backhoe to my place for a demo before I bought it.
   / Just arrived and hour meter is broken #107
I don't think that this situation tells us anything at all about buying used or buying new.
What it tells me about mostly is that a buyer should always inspect anything - whether new or used - to make sure that it is what he wants.
And maybe a little bit about the real value of using price as the determining factor in a purchase.
Condition is what matters,
rScotty
For all the harping on going to see the tractor prior to purchase. 2 points. 1 is that I'm a nurse at a very understaffed hospital. That many days off in a row doesn't happen. 2 is that it is incumbent upon the seller to accurately represent their item, point blank - full stop.
What youre all eluding to without enunciating it is physically looking at the tractor as part of a "wise" action. Without the inspection, small things can slip through, but representing the major components is part of the sale, not a paint scratch.
   / Just arrived and hour meter is broken #109
Maybe you should have bought a tractor for a local dealer, paid a 3rd party mechanic to inspect it or bought a new tractor. Point being you should always inspect used items prior to purchase.
   / Just arrived and hour meter is broken #110
I'm sure there are other ways of estimating the number of hours on a tractor short of an hour meter. Does anyone have suggestions as to what to look at?
JOHN DEERE 2030 TRACTOR (A52708)
JOHN DEERE 2030...
2,500 GAL. POLY FLAT BOTTOM STORAGE TANK (A58374)
2,500 GAL. POLY...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
Unused 20x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 20x20...
2020 DRAGON ESP...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
