Thoughts on towing this with what we currently have
/ Thoughts on towing this with what we currently have #1
bazman82
Gold Member
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
So, we are wanting to upgrade our horse trailer to this:
It has an empty weight of 9500lbs.
We use a 2015 chevy silverado 2500hd 4x4 crew cab. It has the 4.10 in it and is rated at 14k for the fifthwheel. Currently we pull a 2003 4h keifer with a 6' shortwall that has an empty weight of around 6k lbs.
I believe its in the trucks capabilities but man, that trailer looks long and fits the needs of what we want.
/ Thoughts on towing this with what we currently have #2
Way too much trailer for your truck.
We get cowboys come into town each year for Frontier days with those rigs. All of them are hooked up to at least a one ton dully, and they look too big for those. Most are hooked up to a medium duty lite semi truck.
Those things are heavy, especially once you put a few horses and tac inside.
/ Thoughts on towing this with what we currently have #3
They would have to consider the water in fresh water tank(s), grey water tank(s), black water tank(s) plus food, clothing, kitchen stuff, etc. for those who are traveling. It all ads up.
/ Thoughts on towing this with what we currently have #4
Think I'd loose that truck and get a 1 ton dually. The day I spent 79 grand on a horsey trailer, I'd have a large lump on my head where the wife smacked me with a pot.
You obviously have more money than I do or less sense than I do, or maybe both.
/ Thoughts on towing this with what we currently have #5
You must also consider the Gross Combination Weight Rating (GCWR). GCWR is the total allowable weight of the completely loaded vehicle and trailer including any passengers, cargo, equipment, and conversions. The GCWR for the vehicle should not be exceeded.
The GCWR for you vehicle is likely around 20,500 lbs.
Correct, I believe it is around the 20500lb rate. I know the newer 2500's have a larger towing capability but I'm also looking at how often we tow with 3 horses. 90% of the time we would be hauling 2 horses. One weighs around 1k lbs and the other is around 850lbs. I figure about 1500lbs of cargo including hay and water and everything else. We usually don't go for long stretches of time. I believe the truck itself is 6300lbs, I'll have to look when I get home.
Most likely don't have more money but probably quite a bit less sense. It's partly the wife's idea to get the bigger trailer. She wanted a 4 horse with the same LQ set up. I'm lucky I talked her down to the 3 horse. If she would've listened to me a few years ago then we would have the bigger truck already. So here we are, wanting to trade in our travel trailer and 4 horse weekender for something that'll fill both needs with 1 trailer.
I am slightly concerned but the numbers fit within the specs. I also feel in about 2 or 3 years, we would be upgrading the truck. Might jump into a 1 ton, but if our current can pull this without issue, then no reason to go with 1 ton when the newer 2500s have a higher towing capacity. Just have to make sure it can handle the payload in the bed.
/ Thoughts on towing this with what we currently have #8
You will likely find the hitch weight is more than your single tires can handle. That's mostly what one gets with a dually. Weight rating of tires and stability of 8 sidewalls when cornering.
/ Thoughts on towing this with what we currently have #9
That's lot trailer for your pickup :eek: HD dually and darn good trailer brakes.
I know it looks big, it's only a few feet longer than our current gooseneck. Our current is 32ft, I believe this one is 38ft overall. The weight is within limits and I can check the tires but I've towed our dump trailer with 5 tons of stone without issue and that's a bumper pull.
I'll double check the specs on the truck for weights on the rear end and try to figure the math for the weight that size trailer will put in the bed too, I've considered airbags to help with stability if needed too..
/ Thoughts on towing this with what we currently have #11
Also 5th wheels usually will have between 20% - 25 % of the trailers weight on the pin. That means will have between about 2600 lbs and 3200 lbs on the pin. Be sure to consider the rear axles weight rating (usually on a decal somewhere around the drivers side b pillar) and the rating of the tires.
The driver side door decal says 2800lbs for cargo. The glove box says 1975lbs for a truck camper... it'll be something I'll have to consider. The truck weighs 6398lbs. The gross combined weight is 20500. Why rate the truck to pull 14k lbs when the bed can't even handle the weight to go in it to pull that..
Our current trailer.
/ Thoughts on towing this with what we currently have #14
/ Thoughts on towing this with what we currently have #15
I will say that my wife raised Percheron draft horses and would show them and sell them and those nags are all very heavy. We had a tandem axle Moritz stock trailer (GN) and I pulled it all over God's creation with my F350 one ton diesel. Best thing she ever did was get out of the horsey business. Horses are like boats, a boat is a hole in the water you pour money into and horses are the same. I do like the 'gentle giants' they are very docile and easy to handle but we are done. Sold the Moritz and just sold the pickup truck.
I know one thing and that is, your outfit cannot pass a fuel station. Gas and diesel are going up, way up and soon.
We camp and trail ride with ours. For us, that's relaxing and fun and having the ability to wash up afterwards is nice as we get older. I'm sure prices for fuel will keep on the rise but still...maybe I'll switch gears and look at some duallies
/ Thoughts on towing this with what we currently have #17
We have a slide in truck camper that is rarely used anymore. Much nicer to stay in a motel with clean sheets and a Continental breakfast. We own almost 150 acres in northern Michigan, all hardwood, nice trails and plenty of game to shoot. I am very thankful all the horses and livestock is gone.
So looking at newer trucks. The 2021 2500 have payload capability of 3965lbs and towing of 17100...maybe we can do that
/ Thoughts on towing this with what we currently have #19
Gas or diesel? I'd stay away from the gas motors. GM is in love with the sequential cylinder delete and it causes engine failure. Far as the Duramax goes, if I were you, I'd look for a late model RAM with a Cummins and Asian tranny or an Allison. The Allison is bullet proof, you just need to change the fluid and filters on schedule.
RAM suspensions suck but then so does GM suck.
I kept my 97 Ford F350 4x4 4 door long bed and sold it for more than I paid for it new. Ford OBS 7.3 diesels are in very high demand today and mine was the forged rod engine.
/ Thoughts on towing this with what we currently have #20
We have a similar Lakota trailer (15 foot sw, 12500 GVWR) with a hay rack. Water and hay for the horses can be a storage problem, Tack plus outside chairs/tables, grill add up too. All said and done I use a 3500 dually and wouldnt trade. Never measured pin weight but she sure does squat when the trailer is on. Airbags resolved that for me.
There are quite a few that show up at the camps we go to that have similar set ups using a 2500 so I guess it can be done.
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2014 F-150 STX (A56438)
2014 F-150 STX...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
