Tire loses inflation when turning.
   / Tire loses inflation when turning. #1
jlanglois
Member
Ford 3930
The right front tire on my Ford 3930 has a slight leak. I add air about once a week to keep the pressure at about 36psi.
I have noticed that the side wall flexes and it loses most of its air when turning.
Is that the sign that the tire (about 5 years old) has lost the will to live?
   / Tire loses inflation when turning. #2
Would make me wonder if there isn’t either a weak spot in the side wall that flexes and leaks under certain conditions. How does it compare in flex to the other front tire?
   / Tire loses inflation when turning. #3
I had the same situation with my right front tire on my 1700. What I did was to raise the front right tire with a jack stand under. Then I took the scharader valve core out, took a 4lb hammer and beat side wall while turning the wheel hoping to brake the bead a bit. Then made a dish soap water mix, put in a water bottle with a hole in the cap (squeeze bottle) and flooding the bead while turning the tire. I then put the core back and put air a bit higher than normal pressure. I let the wheel on jack stand for a day before I lowered and it helped my very slow leak.
   / Tire loses inflation when turning. #4
I had a tire with a slit in the sidewall. It wouldn’t leak unless the slit was at the bottom where it flexed a little bit. It’s easy enough to soap a tire down to see where it’s leaking.
   / Tire loses inflation when turning. #6
I'm a firm believer in tubes. None of those problems with tubes.
Yes, with a tube it goes flat immediately rather than take hours. I don't think that is better.
That it is leaking slow suggests the tire is tubeless. The O.P. can try adding Slime which may or may not help. As others have said it may have dirt or grime between rim and tire bead that can be disturbed by breaking the bead, lubricating, and re-inflating.
If you decide to band-aid with a tube the installer will curse your name if you have used Slime. The tire has to come off and inside washed with water.
   / Tire loses inflation when turning. #7
Tubes are a good fix for tires that already leak but when a tube does leak it’s usually a total loss and you have to break the tire down and repeat the process.
   / Tire loses inflation when turning. #8
I have had real good success using the John Deere goop. My name for it not theirs. I think they just call it tire sealant. It does not rust the rim and is easy to clean out. I had a front tire that had very bad dry rot cracks that leaked in multiple places around the tire. Put the goop in and ran that tire for two more years without having to add air.
   / Tire loses inflation when turning. #9
I have not been to a tire store in decades.
   / Tire loses inflation when turning. #10
I have one in my little town. They're worthless. They couldn't patch my tractor tube. It went flat the next day. I took the tube out and apparently, they just put a patch over the top of mine. I got a tubeless valve, juiced the tire with a little Slime and it's been holding air since.
Survey Kit (A53316)
Survey Kit (A53316)
2020 Mathieu MC210 Azura Flex Street Sweeper (A55851)
2020 Mathieu MC210...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
SDLanch SDLD25 (A53316)
SDLanch SDLD25...
2014 Chevrolet Equinox SUV (A55758)
2014 Chevrolet...
Giyi 59" Log Splitter (A53316)
Giyi 59" Log...
