Not using all my horses by design??
   / Not using all my horses by design?? #11
I've never kept track of fuel usage but a bigger horsepower tractor will typically use less fuel because the motor isn't being run hard at rated rpm than a smaller one that is. Fuel usage isn't something I get concerned with anyway.
Fill er up and go! Using $3 a gal farm diesel. Seeing $6 gal road diesel again here. Sheesh.
   / Not using all my horses by design?? #12
Only going to get worse Scoot. I don't get concerned with fuel usage anyway as it's a farm write off.
I can see even ORD going to 5 bucks a gallon in the not to distant future.
That will really put a crimp on the hobby tractors that most on this site have.
The thing you have to realize is that as diesel fuel increases in cost, so does the cost to move anything via truck and rail and ship as well.
Regan's 'trickle down effect' in full swing.
   / Not using all my horses by design?? #13
Does having too much HP potentially cause problems if you run the engine at a lower rpm because you don't need all the HP and maybe then have more regen issues?
Good question. I might have to do WOT periodically with a load to burn out the carbon.
What about being an 8 speed? I figured with the HP it'd be equivalent to a 24 speed with only needing a fraction of the output. Is that faulty logic?
   / Not using all my horses by design?? #17
I'm averaging 1-2 gal an hour mowing moderate hills in the MX5200 with loaded tires. It stands to reason you are better off having a little more HP than needed vs running the dog poop out of a barely enough power unit when it comes to wear and tear and machine longevity. I usually don't need 50+ hp. My 7' flail mower calls for 35hp at the PTO. But I need 50+ and more when I sink the rippers into this clay soil.
Go big or go home sorta applies within reason
Not to be controversial but you are confusing HP with torque. HP is a measurement of time while torque is a rotational force. I only mention it for those new to engines designed to do work. Knowing the HP and torque numbers and at which RPM those are achieved is always a good thing. Peak HP at low RPM is a good thing with a tractor IMO. For example a 40HP tractor making peak HP @ 2200RPM is making around 95ftlbs of torque. That same 40HP engine making its peak HP @ 2600RPM is making around 80ftlbs of torque.
   / Not using all my horses by design?? #18
If you are running a PTO implement, you'll have to run PTO speed regardless. I assume it doesn't have 540E PTO like some tractors do, so you can actually get 540 PTO while at a much lower engine RPM?
I can run 540E on my tractor, use less fuel, and have plenty of hp... But without it, I still have to run 2500RPM to get 540rpm from the PTO, whether I need the power or not.
48hp and I burn 1gal/hr
   / Not using all my horses by design?? #19
I've been experimenting with how often and long my Kubota regens. It definitely does regen more often and for longer when run at lower rpms.
I'm not sure if that is to me or not. The HP is rated at 108. I am not mistaking that for torque. The peak torque is at 2206rpm on this engine, but I forgot the number.
With that, my use range would be significantly lower as I don't need that much power for pretty much anything I'm going to do or use.
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2022 CATERPILLAR 315GC EXCAVATOR (A52707)
2022 CATERPILLAR...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
