Good morning!!!!
   / Good morning!!!! #174,931
Good Morning Guys,
Happy Birthday to Mrs. Kilroy !
PopG, I have a 1/2” drill similar to yours, yes, have to be careful with all that torque !
58 to start going to 75 with much less humidity and some Hellblau skies today !
Going to need a couple large loads of crushed process in the DW before cold weather sets in !
Today looks like re mow the lawn and squeeze a pontoon ride in later this morning ! Some company coming in tonite, so try and get done before that !
Hope all have a blessed and safe day ! 🙏
Buppies, yes the old skin is not what it used to be ! 😉
   / Good morning!!!! #174,932
Think Waze somehow directed me by the sellersville theatre one day…..
I’ve been finding Waze to give some aweful directions.
Waze has been giving me directions that are contrary to what I would have done on my own, but the time estimates are accurate, and have actually saved me time. I think that it pretty actively considers traffic and road conditions, causing different routings.
   / Good morning!!!! #174,933
I used to listen to them a lot, and Commander Cody and his lost planet Airmen.
Happy birthday from Texas to Kilroy's wifey!
We don't really get used to this heat anymore. I would guess you would have to live totally w/o A/C to get acclimated.
We have a 4 ton A/C, and it is working overtime, not shutting off between 2 to 10 pm. The temp inside will climb up to 81 with the heat load. Maybe I need to check it's pressures to see if it is low on freon. It is pulling a lot of heat out of the home.
"Lost in the Ozone again"
   / Good morning!!!! #174,934
   / Good morning!!!! #174,935
I believe this upcoming winter is going to deplete that pretty quick
There's another full rack to the left, around the corner of the barn. Couldn't fit it in the camera frame.
   / Good morning!!!! #174,936
Bill Kirchen, the lead guitarist from Commander Cody is a regular at the the sellersville as well.
A simple no tools test of the charge on your AC is to go out and feel the suction line (larger one) as it goes into the condenser. If it feels like a beer that just came out of the fridge, the charge is likely ok. If it’s warmer, or not sweating it needs attention. And if it’s ice covered, it’s seriously undercharged.
"Lost in the Ozone Again", "Seeds and stems" and"Hot Rod Lincoln"
...my misspent youth...
   / Good morning!!!! #174,938
$3.69 gallon...OTR diesel $4.05 gallon here. 🙄
Morning all;
Supposed to only get into the low 80's here today with a good amount of humidity.
I would like to see gas prices like that;
we are already over $4 per gallon for gas.
Yesterday was $4.03 for regular and $4.49 for diesel.
I filled up late last week and wanted to check out how my truck did on a trip so I filled up with mid grade which was $4.29 last Friday and the truck did do a 19.8 mpg mostly highway run at 70 mph. Now it's time to fill her again. Back to regular, the best it got on regular was an 18.6 mpg on similar runs (2019 RAM 1500 5.7 crew cab).
Contractor should be here in just a bit to continue on soffits and fasia, when we opened up the soffit found some more shoddy workmanship and materials had to redo all the sub framing for the soffit and some of the sub fasia.
   / Good morning!!!! #174,939
Last week in TN, I needed to go west, then south on major roads. Waze decided I needed to cut the corner. 😂. So I decided to follow Waze down a zigzag path thru old residential streets, and finally to the road I needed, but I had to take a left on a busy street with no traffic light. 😂
   / Good morning!!!! #174,940
Those VRBO ads I see make me wish I was
there especially those snow scenes feet and feet of snow. I can almost see Thomas out front in yard
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
2019 GALYEAN...
205196 (A52706)
205196 (A52706)
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
