Suggestions on 20” pro saw
   / Suggestions on 20” pro saw
I prefer Stihl because they extensively support the USA, not woke and my dealer is close by and a good dealer.
   / Suggestions on 20” pro saw #62
It's all stihl around here, but I've got 3-1980's Echos. EVL550, EVL440, and EVL400. All three have serviced me great for over 30 years with no primers, hose replacements, etc. In fact I sold my newer stihl farm boss. I don't know about the new echos, I sure like turning the fuel adjustments with a screwdriver though!
   / Suggestions on 20” pro saw #63
Recently bought a 194t to compliment my 500i. I should have bought a 261 instead and may do so anyway.
   / Suggestions on 20” pro saw #64
I have a 261c with 18 inch bar. I’ve run that for 6 years I think. It’s in my truckbox sonits usually the first saw I go for. I probablybwouldnt put a 20 inch bar on it unless I was only doing occasional cutting. The reliability is there, I had a cooling fin break on it and it just keeps on going without any other issue.
If I was looking at another saw, provided there was sufficient support, I would look at Dolmar or Makita( same saw). I have three and have worked them hard.but the Stihl has been reliable and I wouldn't feel cheated if it was issued equipment for a job.
   / Suggestions on 20” pro saw #65
I have an echo CS490 /18"/20" as my little saw and a CS620P/24" as my bigger saw.
Seems like you want something in between.
The Echos are slightly heavier for the power, but so much less $.
   / Suggestions on 20” pro saw #66
Echo website
I have a couple Huskies and a Stihl but the saw I keep turning to is an Echo CS-501P. It's lighter weight but still cuts like the big boys.
I still have my Makita/Dolmar 6401 with 24” bar for bigger jobs.
Reluctant to get another because makita has stopped manufacturing saws.
   / Suggestions on 20” pro saw #68
I have always owned Stihl, just what my dad bought, what I learned on and never had a reason to look elsewhere. I have a 029 that I bought about 1997 and it's still going. I cut 7-8 cords a year between my house and my neighbors. I bought a used proMS-391 a couple years ago, run a 25" bar on it, I wanted a step up from the MS-390 I had and it's a world of difference, just so much more power without the bulk. I also run a MS211 for limbing, more power than the MS170 I had, but honestly less reliable once it's warm. Just doesn't like to start again, where the 170 would run all day. The MS029 is a bit tired and low on power, but for the sub $300 price back then, & never having it in a shop for service ever, it doesn't owe me a damn thing. I may just retire it and go with a MS261, I like being able to adjust the carb if needed, so I'll pass on the auto tune for now.
   / Suggestions on 20” pro saw #69
I will check that one out.
I liked the price of the 261C at $699. We have Stihl sale this weekend 10% off, so I’d be at a hair over $600.
What size and kind of wood are you generally cutting? What saw(s) do you currently have? How often are you cutting? When you cut, how long are you cutting at a give time (ie 15 min to get a limb out of the way, all day to get firewood prepped for winter, or somewhere in the middle?
I run Stihls, and can't really comment on any of the other brands. I have an 024, 026, two 036s, 064, and an 066. My 024, 026, and both 036s wear an 18" bar and run .325 chain. My 036s are set up to run 9 pin rims and I run the depth gauges shorter than spec (.030 to .035). They outrun my 026 by a fair amount, and would come very close to keeping up with my 064 when cutting stuff in the 12" range. I normally use the 026 for limbing and cutting stuff under 8" (which isn't much), and the 036 saws do most of my felling and bucking.
I'd pass on the 362. My understanding is that it's a turd compared to the 034S/036/MS360/MS361. If you really want a Stihl in the 60cc range either find a used 036, MS360, or MS361.
Practically speaking, I wouldn't go any smaller than an Ms261. Their smaller saws are only a LITTLE lighter, but you loose a LOT of power. The 261 was a noticeable step up from the 026/MS260 (3.5 hp to 4.0 hp). I've not run one, but at a measly 10 lbs, 4.0 hp is a lot of power for such a light weight saw. Personally, I would recommend running it with an 18" bar instead of a 20". I'm sure it will pull a 20" okay, but its extra bar and chain length that the engine has to pull, and weight you have to carry around. My 026 saw does okay with an 18" bar, but would be better suited with a 16" (I mostly cut hickory). A friend of mine has multiple 026 saws that he's been using since they were new and came to the same conclusion many years ago. He runs 16" bars on all of his 026 saws. I only run the 18" to minimize the number of different bars and chains I need to keep track of. Based on the saws I have, and how I use them, I'd say the 261 with an 18" bar would be a great option if 75% of what you're cutting is under 20". If you're routinely getting into wood that's over 24" across, then I would look at something bigger. That would be either a used MS361 (or older), or a new 400 (almost the same weight as a 362, but significantly more HP) which is going to be expensive. My guess is that the sweet spot for the bar length with a 400 will be 24". Realistically, between the 261 and the 400, Stihls 360 series of saws is becoming obsolete.
   / Suggestions on 20” pro saw #70
I have a Husq 545 20" which is a pro saw. It was ran over by a Ford Explorer - both wheels completely over the saw. I ordered the parts to repair it but while waiting bought a Husq 545 Mk II.
It has easy pull on it and literally takes half the effort to pull the rope as my orig 545. It has auto tune and starts very well.
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
