Pouring steps down to the creek/swimming hole...nope, never done it before!
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
Last year, we had a bank erosion project completed on our creek that runs through the property. 300' of fabric and 120 tons of rip rap. In the summer, the water is low, and the creek is about 7-8' down from the pasture. So, with the angle of the rip rap bank, I need about 12' of steps. Trying to walk/crawl down to the creek right now is hazardous, but necessary if you are going to take a dip in the swimming hole. Flooding in spring can be 2' over the banks and completely cover my pasture out to the paved road. For this reason, wooden steps will not work.
Since I have never done this before, I Youtubed it, and now am a confident (cough)expert. Stair tread/rise calculations hurt my head, so I keep a 4' HomeDepot pre-cut Stringer handy as a template. I bought 4-12' 2x12x12 boards and marked out the risers and treads.
So, put 2x8 risers on the Stringers 2' apart(width of stairwell), drag it down to the creek and find a suitable spot to set it on top of the rip rap. I figure a 3x3 top and lower pad all tied together with some re-bar.
Will take new pics of the creek and proposed stair location......stand-by.
What could go wrong pouring 24 steps??
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #4
Plenty. ;)
Just a couple of concerns for me would be:
If the lower pad is placed where moving water will hit it, it will, someday, get washed out. It's called scouring.
If the sides of the stairway get submerged in moving water, they will get undermined at some point. Then the only thing holding them up is the other steps.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #5
Plenty. ;)
Typically the steps have rebar along the length and foundation at the bottom
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #6
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #7
So does a bridge abutment. It still scours. Unless it's bolted to bedrock or on deep pilings, if the water comes fast enough long enough, it washes out.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #8
I'm not saying it's gonna happen in this case. It's just a concern that would be easier to think about now just in case. ;)
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #9
If you're only using it for access to the swimming hole, why not turn that concrete form you made into a staircase? Use the tractor to set it in place in June and take it back out in September.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #10
Was your erosion control with the fabric and rip rap engineered?
If it was, talk to the engineer of record and ask them what the effect of placeing a concrete dam (staircase) that catches the weight (velocity in cubic feet per second) of the rising and falling water has on the rip rap. I think you will be surprised by thier answer.
Would need to know the size of the rip rap and the flow of the stream in cfs to really give any help on this.
My thoughts are that the staircase will cause the rip rap to scour causing movement. But I don't know the elevation change at your site and the velocity of the flow in the creek.
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
(INOP) HONDA RIDING MOWER (A58374)
(INOP) HONDA...
