Does Anyone Buy Used Tractors?
   / Does Anyone Buy Used Tractors? #231
I can't recall right now but seems there was some JD compacts with an aluminum rear housing years ago. Any help here folks?
Awww, chit. I'm heading out to the shed with a magnet tonight, after I'm finished my desk work for the day!
   / Does Anyone Buy Used Tractors? #232
Pretty sure it was the E model JD compact tractors with aluminum rear ends.
   / Does Anyone Buy Used Tractors? #233
I doubt it. But the way progress happens is that someone flies in the face of convention. Sometimes it works, and sometimes not.
Where it is working right now is in the Sprinter commercial vans. They have all aluminum Mercedes Benz turbo diesel engines. Tiny very powerful engines. The whole Sprinter Van and Sprinter powered RVs are incredibly long-lived and reliable. Rarely need maintenance, and popular for economy in spite of the purchase price. But they are throw aways, not easily rebuilt.
   / Does Anyone Buy Used Tractors? #234
Wow, jjeff! Are they actually making axle castings out of aluminum on some tractors, now? A pump housing, I can understand. But an axle is a vastly different situation.
Unsure but wouldn't surprise me in the least to see it happening I was drifting and mostly referring to cheap thin pressed steel on big box store riders for front axles.
   / Does Anyone Buy Used Tractors? #235
Sorry for the crappy photo but its all I could locate at this time.
Rear axle housing cracked on Deere 4300​
10659 Views 16 Replies 9 Participants Last post by dragon, Oct 31, 2015 Jump to Latest
dragon Discussion starter · Oct 18, 2015
Hello, I recently took the wheels off my tractor to install the third scv and found that the bolt holding the retainer onto the rear axle housing had broken off along with a chunk of the aluminum housing. I've had the tractor for about a year with no major problems and I probably wouldn't have even noticed if I didn't install the scv. I'm in the process of taking the axle housing off now but wanted to get some opinions on how to proceed. New housings are still available but are about $1,000 each. Any other options? Thanks
   / Does Anyone Buy Used Tractors? #236
I suppose weight was a consideration if you want to tow your sub compact tractor with the family minivan or crossover, aluminium component laden tractors are your friend lol.
   / Does Anyone Buy Used Tractors? #237
As I recall some JD smaller units have aluminum housings
   / Does Anyone Buy Used Tractors? #238
I'd guess it was cost of the casting, not weight.
   / Does Anyone Buy Used Tractors? #239
Probably many factors for keyboard commando speculation lol.
   / Does Anyone Buy Used Tractors? #240
Interesting if the Deere 3E's use aluminum. I'll check my 3R tonight, if our weather holds.
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2013 Express 20' Cargo Trailer (A57148)
2013 Express 20'...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
9ft Reading Service Bed (A57453)
9ft Reading...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2013 CAT 312EL Excavator (A59213)
2013 CAT 312EL...
