Driving tractor with the front end loader bucket elevated .
   / Driving tractor with the front end loader bucket elevated . #11
I also run mine low to the ground.
Another thing that gets me is during hay season EVERY tractor I see on the road with a loader mounted hay fork has it tilted back at almost exactly head height. Point the thing at the road people!
   / Driving tractor with the front end loader bucket elevated . #12
I usually have the loader off when mowing but I too use it in unknown territory.
What I don't get is seeing people baling or raking with a 100 HP or more tractor and the loader and bucket are ALL the way up!! For visibility I am guessing, . . but there are some major forces on that poor thing rocking back and forth way up in the air.
   / Driving tractor with the front end loader bucket elevated . #13
Very flat surface area, and grasses less than two feet tall, known area, bucket is up.
   / Driving tractor with the front end loader bucket elevated . #14
Only 1st pass I drive with mower behind me, after that I use the full extend of the ditch bank flail mower and drive in the 1st pass track. It also sucks in way less stuff into radiator when I do it this way.
   / Driving tractor with the front end loader bucket elevated . #15
I keep my bucket elevated to prevent it from bottoming on the uneven ground I mow. If I'm in an area with difficult visibility, I'll remove it.
   / Driving tractor with the front end loader bucket elevated . #16
On construction sites you’ll rarely see moving equipment with the bucket high in the air. Loaders in a gravel pit are different though.
   / Driving tractor with the front end loader bucket elevated . #17
We keep the loader bucket or bale forks rotated up while roading the tractors or doing field work with them on. If pointed down if they contact the ground it is going to cause a lot of damage. With it rolled back it will skid along the ground and not dig in.
   / Driving tractor with the front end loader bucket elevated . #18
My dad ran over an unseen bike with his little ford and a bushog. Made a racket.
   / Driving tractor with the front end loader bucket elevated . #19
I try to stay low. I have to lift it to get through gates when the fork is loaded, however. When I carry a lot of debris, the FEL is usually a couple of feet off the ground to prevent things hanging off of it from catching on weeds and things.
My most fun experience with the FEL came while using a rope to pull shrubs. The rope was not centered, and when the FEL went up, the tractor started rolling onto the side with the rope. The speed of the roll was impressive.
   / Driving tractor with the front end loader bucket elevated . #20
I have noticed some people driving there tractors with the front end loader bucket about 3' to 4'ft off of the ground while mowing or brush hogging and I am wondering why some people do so . I always keep the bucket low to the ground .
I have to remove the bucket to put on the Brush hog. :D
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
23105 (A56859)
23105 (A56859)
20 BLADE DISC HARROW, 3PT (A52708)
20 BLADE DISC...
2006 APPA TL (A55788)
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2019...
