Good morning!!!!
   / Good morning!!!! #171,143
Ok, not the greatest success, but, a panoramic view this morning
If blown up, one can see a bit of the far fields on each end.
   / Good morning!!!! #171,144
Amazing view and you keep it so nice. Definitely a great postcard for visit the big island.
   / Good morning!!!! #171,145
Finished a section of the fencing. Using the old fence wire it has some slack in the top wire but so be it. Stretched it as much as possible with the clamp on stretcher and come-along. Have a roll of high tensile wire wire so may run a wire on top. The stapler worked great. Cut off some of the end of an old strap to clean it up for reuse and burned the end to melt it in.
Will work on more fencing in the mornings.
   / Good morning!!!! #171,146
Thanks Ken, we definitely enjoy it. It IS work, but as I was thinking just the other day, work is basically whatever we decide it is. All my jobs pay the same. The in process enjoyment level may vary. In the past, mowing has proven it can be expensive. Get some wild idea for a project and now have hours to dwell on it. Sometimes I get lucky and the idea gets put away when I park the tractor.
   / Good morning!!!! #171,147
David- I always enjoy your pictures of projects and your beautiful property. You and Sophie have created a paradise within a paradise. Thanks for sharing.
Fritz- I am happy to read that the stapler is meeting your expectations.
   / Good morning!!!! #171,149
88Fclear sky steady breeze.
Sunrise was light haze blocking full sun and could detect wood burning smell, Nova Scotia fires.
Work day pass quickly,stop on the way home did food shopping save Mrs. dealing with heat traffic,until early evening just going to keep low profile until mercy lowers.
Plans for the evening...other than setting on the deck shall be all ???'s
Enjoy your day all.
   / Good morning!!!! #171,150
Your repair is coming along nicely.
I believe that Canadian fire smoke must be restricting vision...but thanks for positive thoughts.
got my hair cut, headed out to mow, going to be hot and dusty.
tonight is prom night at local high school, hair stylist was hopping, I watched while some woman had makeup put on her.
what women go through...
war paint
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
NEW Fork Extensions (A59000)
NEW Fork...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
