Link belt for fan belt?
   / Link belt for fan belt? #1
frogpond
Snohomish WA
Kubota BX25D
The fan belt on my bx25d is stretched out and needs replacement. Has anyone tried a link belt for this application? I am hoping to avoid having to detach the drive shaft.
   / Link belt for fan belt? #2
I used it as a temporary fix on an old Massey, 10 years later it's still doing the job.
Do you remember what brand it was?
   / Link belt for fan belt? #4
Temporary. Highly doubt it would handle the higher rpm on a small tractor. The old Massey was a lower rpm engine. Just a wild guess.
Oh, well. I guess I'll find out how frozen are the 3 bolts holding the shaft on. I have a feeling I'm in for scraped knuckles and bad words.
   / Link belt for fan belt? #7
Gates makes good fan belts..
   / Link belt for fan belt? #8
We used a Fenner drives link belt on a Massey with Perkins engine and a front hydraluic pump for a few years because the pump drive shaft was very hard to remove and of course it was cold and snowing the next day. It seemed to need a lot more travel of the alternator to tighten it than a regular belt but it worked just fine even with a small alternator pulley. After a few hundred hours I started to notice cracks in a few links and we got the pump shaft unstuck and put on a good V belt.
   / Link belt for fan belt? #9
Link belts are like those donut tires you see everyone running around on. If I'm doing it I'll be stranded in 30 mins. Anyone else can run them forever with no issue.
   / Link belt for fan belt? #10
This link came up in a google search; doesn’t seem too bad of a job…..just need patience and penetrating oil
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
