John Deere Gator, Kubota, or ... for wet field UTV chores?
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #11
Test drive a Honda Pioneer 700-4. Max speed is 43 mph but has a dump bed. 4wd and power steering. No belt drive.
How does the Honda 700 Pioneer work for farm and ranch use? Is the bed sized well? Specs are pretty thin on Honda's website. At $11K to $13K MSRP, they priced reasonably for the market.
General thoughts on the Kawasaki, Yamaha, Polaris, Canam, and similar recreational-based UTV options?
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #15
My ranger has a bed capacity of 800 lbs. That is about the same as lift capacity on my 1025r loader and it handles that pretty easily. You can go over that a little bit but you would absolutely not want to move a 275 gal tote full of fluid. A lot of times when I'm moving material farther than would be convenient for the little tractor, I'll load 1 scoop into the ranger and go dump it. It does well with that. I put 2 scoops of SB2 gravel in the ranger bed once, it moved it but I would never do it again.
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #16
We have a large tree clean-up company working along local RR tracks and a bridge clearing branches & logs far off road where OTR vehicles cannot access. They are using Gator 6x4’s to bring up men, equipment & branches.
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #18
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #19
I love my Kawasaki Pro-MX midsized.
2009 Ford Econoline Wagon Van, 101,671 Miles (A56438)
2009 Ford...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
3 Point Hitch Single Bottom Plate (A57454)
3 Point Hitch...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
