John Deere Gator, Kubota, or ... for wet field UTV chores?
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #11
Test drive a Honda Pioneer 700-4. Max speed is 43 mph but has a dump bed. 4wd and power steering. No belt drive.
How does the Honda 700 Pioneer work for farm and ranch use? Is the bed sized well? Specs are pretty thin on Honda's website. At $11K to $13K MSRP, they priced reasonably for the market.
General thoughts on the Kawasaki, Yamaha, Polaris, Canam, and similar recreational-based UTV options?
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #15
My ranger has a bed capacity of 800 lbs. That is about the same as lift capacity on my 1025r loader and it handles that pretty easily. You can go over that a little bit but you would absolutely not want to move a 275 gal tote full of fluid. A lot of times when I'm moving material farther than would be convenient for the little tractor, I'll load 1 scoop into the ranger and go dump it. It does well with that. I put 2 scoops of SB2 gravel in the ranger bed once, it moved it but I would never do it again.
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #16
We have a large tree clean-up company working along local RR tracks and a bridge clearing branches & logs far off road where OTR vehicles cannot access. They are using Gator 6x4’s to bring up men, equipment & branches.
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #17
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #18
   / John Deere Gator, Kubota, or ... for wet field UTV chores? #19
I love my Kawasaki Pro-MX midsized.
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55314)
Mahindra 4550-4L...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A55745)
2015 PCI MFG...
