Good morning!!!!
   / Good morning!!!! #168,721
well, partially successful.
Got assembly installed and turn signal did not work.
Determined plastic clip holding contacts to each other had come loose, got clip as tight as I could, tried
again, and the turn signal worked. Along with...the one rear back up light, blinking in unison. That seemed dubious to me so tried the other side.
No, just the one outside light is supposed to light up. So....I've got some wires incorrectly attached and need a second set of eyes to fix this.
At least the turn signal works.
considering plastic clips used, unless I glue them in, doubt it will hold for long with all the banging around it gets.
hopefully my replacement ordered will show up sooner vs later.
hey buddy, ya know your lights are screwed up?
un huh
   / Good morning!!!! #168,723
:eek:...Ground be froze possible snow on the ground when phone call comes in for delivery.
Hail, trees down, overturned tractor trailer, cows in The road…
   / Good morning!!!! #168,724
Have a mystery. Found a red ball somewhat bigger that a tennis ball and heavy plastic. Was out in the middle of the field and ran over it mowing. Did not notice any tracks and was too far to be thrown . Any of you recognize this?
View attachment 797785View attachment 797786
It belongs to the neighbor’s dog - his name is on it 🤣😂😂
   / Good morning!!!! #168,725
Mowing with the ZD331 went fast today going full speed. Helps with fresh sharpened blades and air suspension seat air pressure at the lowest to get the most bounce without bottoming out.
The woods mower I had it set for 3 remotes so I could lift each deck independently
   / Good morning!!!! #168,728
51F clouds rolling in rain around 9pm ending around 3am.
Been good day...several little jobs done outside,Kubota got some TLC and soapy bath.
Plan for the evening...set on the deck see what critters show up,watch some YT keep recliner company.
Enjoy your evening all.
   / Good morning!!!! #168,730
Kil, you may want to look over this Utube on excavator in operation if you have not seen this before
Fwiw I am about 30 seconds I. And I remember watching this guy when he was adding the second level of containers to his castle - I haven’t looked back at his stuff in several years! THANK YOU - I need to catch up on his stuff!
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
2016 Ford E-450 Passenger Bus (A56858)
2016 Ford E-450...
Butterfly Artwork (A55758)
Butterfly Artwork...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Garden Tiller (A57454)
