Sad and Tragic Recovery Accident in AZ.
   / Sad and Tragic Recovery Accident in AZ. #12
Here's a pic of connecting two looped ropes/straps without iron.
   / Sad and Tragic Recovery Accident in AZ. #14
Pretty sad story and a good video, I leaned a lot.
I agree. Had no idea the hitch ball was so weak. Have to check out some of the other equipment that he told us about. Also really wondering about those towing loops on my F150. How strong are they? Can’t seem to see much on the Internet about it.
   / Sad and Tragic Recovery Accident in AZ. #15
I have loops on the front of my 2017 F150, I also wonder how strong they are.
   / Sad and Tragic Recovery Accident in AZ. #16
I've offroaded for 40 years. Experienced hundreds of stucks. Bought my first stretch rope in 1975. Our group now carry a dozen of them.
1. Both vehicle drivers should always lay over in the seat just before impact. Get their heads below line of sight.
2. Avoid mixing items if at all possible. If you must do so, NEVER use a metal object as a connector. NEVER. There's a very simple way to connect two ropes or straps with loops. Easy to connect. Easy to disconnect.
3. Back to mixing. NEVER use a chain with a stretch rope. NEVER. None of our group even carry a chain. ALWAYS use a heavy static strap or rigging rope connected with the simple loop method. No iron in the mix.
4. Educate yourself to the forces involved using a stretch rope. They can quickly exceed the limits of anything mixed with them. NEVER mix iron into the equation.
5. Understand that the introduction of the stretch rope into the equation rapidly exceeds the capacity of the hitch points. I once saw a receiver hitch assembly ripped off the frame of a ton truck.
Sorry to hear of the loss of life. My rule #1 above would have ensured that couldn't happen.
Only thing to add to these guidelines is We always put the hood up on the stuck vehicle if we suspect it will be a hard pull, that way it will stop or at least deflect the object down and stop it from hitting the windshield.
I couldn't hear the video where I am now and maybe he mentioned it.
I don't have any of the kinetic pull ropes, mine are all the older style straps.. Winches are our biggest used item anyway as on the trails it's rarely possible to get another vehicle in a straight line and a good position with good traction to tug. But we always throw something over the winch cables as well.
   / Sad and Tragic Recovery Accident in AZ. #17
I suspect the failure would be moumtimg bolt shear, or tearing holes in the frame. The loop itself will most likely exceed those two possibilities.
   / Sad and Tragic Recovery Accident in AZ. #18
I learned quite a bit from the video and ovrszd. While I never have used a ball mount as an anchor point or tow point, I have done some of the other bad things (ie static strap and chain used at the same time). Thanks guys.
   / Sad and Tragic Recovery Accident in AZ. #19
This is a photo of the accident site from the article.
First bad decision was attempting to tow from the front. Seeing as the truck was stuck down to the front frame, towing the truck back out from the other side of the trail would have made more sense.
Second bad decision was attempting a line of sight tow. Given the drop hitch was at eye level to the stuck driver using a tape fabric tow line.
Third bad decision was to attach the tow strap to the ball of the drop hitch. As trucks got taller, the hitch stingers had to compensate, and I've seen insanely long drop hitches to compensate for lifted trucks. Drop hitches are inherently weak by design. The entire concept of a drop hitch is just wrong. It needs an entire new design with some extra bracing to reinforce the right angles to be certified for a tow capacity.
Fourth bad decision was to use a running start to yank the stuck truck out of the hole. This is always a bad idea. Repeat... Always a bad idea.
And last and most important bad decision, was not just abandoning the truck there, after the first few attempts at a forward pull out didn't work, and have the friend drive everyone home for the night. Figure it out the next morning. The first posted photo of how stuck that truck was, I would have just said she is done, if they couldn't pull it from the rear.
I've walked away from stuck vehicles, till better knowing people with better equipment were called in. It doesn't make you lesser of a 4 wheeler to say, this is a total mess up, and beyond my ability to fix.
These small bad decisions added up to a fatality. Each step, was considered to be okay, yet together, they add up to potential energies that make for a very dangerous situation. In this situation, all those bad decisions ended up with a very bad result. I can feel for the friend that came to assist. He has that bad outcome to live with forever.
   / Sad and Tragic Recovery Accident in AZ. #20
I think they were using a non stretch strap. But I'm not positive about that. If so, getting a run at it caused extreme pull force on the hitch for just a micro second.
Stretch straps or ropes are designed to be used in a "get a run at it" situation. They soften that micro second extreme force. But as they stretch to their maximum they magnify the force on the hitch points.
A Jeep for example would be able to pull out that much larger vehicle using a stretch strap or rope. That's why they are so frequently used and what they are designed to do.
But again, it appears this was a normal strap. If true, I'm a bit surprised by the kinetic energy displaced at the moment of failure.
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
