torch1
- Joined
- Oct 24, 2013
- Messages
- 22
- Location
- White Fox Sask.
- Tractor
- M/F 1528HL, Case G530CK Backhoe/loader
Interesting posts and some good information, some not so good.
if you have winter fuel, and you use a hair dryer to heat your filter, your result will only be temporary as you are only changing the specific gravity of the fuel within the filter, once started you will then draw more of the summer fuel into your system.
Winter fuel will give you a Horsepower loss of approximately 5% of your rated power?
Diesel fuel does break down so do not keep large amounts of fuel you are not going to use in a month or two. This problem is called fuel bug, check it out on Google.
Your fuel supplier should be able to tell you when they will switch to winter fuel, if not switch to one that will.
I am not familiar with how much fuel everyone burns in the winter, but I am thinking a lot less than in summer. If possible use up all your summer fuel before fall so you eliminate part of the problem.
If this is not possible, get a separate tank for winter fuel or even use Jerry cans for winter.
Always drain the sediment and water out of your main supply tank and tractor, at a minimum of monthly depending on quantity of fuel you use.
Keep tank fill caps under cover from rain and snow and insure all vents are also clean and open.
Change your fuel filters, all, before every winter season, “no exceptions” and keep spare filters of each type you own.
Water separators are very handy and if you continue to see water in the drain side they are telling you that you have a problem with your fuel supply system.
Fuel deicers and water removal fluids are very handy and do work, use a quality product, check with your local highway haulers for advice on what they use. When not mixed do not be confused if they appear to be gelled, they will do this as they need to be mixed with fuel to do there job.
Servicing is the cheapest part of owning any machine, do not try and cheep out by missing services or change intervals. Filters are cheap, water and contamination in your fuel system will destroy them and then the real money is going to be spent.
This information is not brand specific but will work for 99% of the units currently in use.
I live in Canada and have a very good understanding of what is reguired to run diesels in winter conditions. Cheers
