You'll correct this.
/ You'll correct this. #1
JasperFrank
Elite Member
Ford 1220
She says I'll just correct this.... Gottta love your wife even when it is hard to do so.
/ You'll correct this. #3
Need some back story. Did she lay them out and then assume you would fix it? Did you just not meet her expectations?
/ You'll correct this. #4
My blood pressure is rising vicariously for you as I've been there more than twice...
/ You'll correct this. #7
Yikes. As someone who's built a bunch of patios that's a sight to behold. Just something to consider is if im going over existing concrete i'll screed a thin layer of sand over it to make up the difference in the block heights. It might not matter enough to worry about but just figured i'd mention it. Some of the block ive had to use vary in thickness by over 1/4".
/ You'll correct this. #8
We've done major paver work twice. 30-40 pallets worth between the two. I'm happy to say that the misses laid nearly as many block as I. (print this off and show your wife :)
I just go out in the garage, work on stuff and other things that need to be done. I know how to correct this. And it will be hard. To re-place everything. This is the very definition of being long married. You let the wife make a mess of things and it doesn't matter. She is happy to set the tiles how she wants, off set, and no lines to follow. This makes her happy. Okay. She will never see the corrections done. Yet they will be done. And the final product will be exactly the thing she wanted in the first place. :)
/ You'll correct this. #12
This brings to mind vividly memories of my grandfather shaking his head slowly and muttering "anything for a quiet life..."
/ You'll correct this. #13
You going to need a wet saw, A steady hand, a good back, and a forgiving eye.
Been there done something like that. The sections in this driveway were not square or dimensional. I volunteered to help. Ended up being the saw guy. And yes his wife was right there putting em in and sweeping sand... and yes the car is mine;)
/ You'll correct this. #16
Nice reward for your cover-up work, but well earned. You earned it.
/ You'll correct this. #18
As someone who as done alot of pavers, and has a buddy that specializes in high end paver patios.....that makes me cringe.
I agree with whoever said to put something under the pavers as a base to level the concrete.
You also need to stagger them a little....too many LOOONNNGGGG straight lines/seams
And if you want it to last and not fight weeds in the joints use poly sand
/ You'll correct this. #20
I often admire member's photo subjects when they post something cool, like a nice car, or tractor, or shop. The mustang is real nice, but the place in the background is sweet!
Do wives have a training class where they learn how to push husbands into tasks? Mine is remarkably good. And her concept of time is remarkably bad. :)
10FT S/A Utility Trailer (A64557)
10FT S/A Utility...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
John Deere Metal Decorative Sign (A64557)
John Deere Metal...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
SKID STEER FORKS (A64553)
SKID STEER FORKS...
