Working rail roads and their tracks.
   / Working rail roads and their tracks. #2,311
Abandoned tracks at the woods edge of a property I farm :/
Perfectly usable, just a bit overgrown. :confused:
   / Working rail roads and their tracks. #2,312
When you don't standardize on one gauge, trackwork gets complicated.
Bruce
   / Working rail roads and their tracks. #2,313
There's a small yard on the SW corner of our town. Occasionally, they bring in this train of living quarters that I assume are for people that are working on the RR tracks in the area.
Kind of interesting. I caught it on google earth.
On the bottom side of that yard, there used to be two sidings where I'd load vehicles from AM General onto rail cars for transport. 5 ton Army trucks that got brought in and refurbished for a government program that was quite successful and saved the taxpayer a bunch. They basically got new trucks for 2/3 the price of new. We also loaded new HUMVEEs and small Postal Service vans.
They all went on flat cars. We'd order in about 20 cars. They'd drop them off. Then we had to lock the brakes on the last one at the ramp, then use pry bars to move them closer together so that we could lift and install steel plates by hand between the cars and pin them down on one car. Then lock the bakes on that car, and move on to the next. Those plates aren't light! :ROFLMAO: But I could do it by myself back then. Sometimes I'd do the entire train while the others went and picked up a load of vehicles. I won't lie. In summer, it sucked!!😓
Then we'd drive them on and chain them down. The government guys would show up, take inventory, check the chains and binders and safety wires, and magically the train would be gone and a new batch of empty cars would appear.
Other days we'd drive them to other towns and different railroads.
Just another part-time job I had in my youth.
   / Working rail roads and their tracks. #2,315
The 2004 Sri Lanka tsunami train wreck is the largest single rail disaster in world history by death toll, with 1,700 fatalities or more. It occurred when a crowded passenger train was destroyed on a coastal railway in Sri Lanka by a tsunami that followed the 2004 Indian Ocean earthquake. The tsunami subsequently caused over 30,000 reported deaths and billions of rupees in property damage in the coastal areas of Sri Lanka.
Bruce
Recently taken near Colton, South Dakota, BNSF railroad.
I took off from work a bit early on Tuesday (OK, a lot early
) to go check out a snow plow being run from Sioux Falls to Madison (?), SD. I carefully drove up a still somewhat snow packed I-29 and then cut west to intercept it. I found the plow getting ready to hit the heaviest stretch immediately north of Colton. I parked my Forester and found a spot to catch the action. The plow backed by three engines began to move and then rammed into the start of the nearly mile long drift. It didn't get very far! Suddenly, the plow was off the rail and at a 45 degree angle on its side. I drove down, got out, and took a look. It was pretty obvious the plow was done for the day.
It looked like a Hulcher moment there. I talked briefly with some of crew. Fortunately no one was hurt but somebody did spill their coffee.
Heavy equipment showed up the next day and began digging everything out. Not only was the plow dug out and lifted back on the tracks using a sideboom dozer, but the entire mile long drift was dug out with a combination of excavators, bulldozer, and tractor mounted snowblower. This took three days plus and I can only guess how many tens of thousands of dollars. The drifts were not only deep (over 10 ft.) but the 50 mph winds had packed them like concrete. I was able to walk on them as if on a sidewalk.
The plow sat forlorn for several days, looking a little battered. A pair of bright orange BNSF engines showed up this afternoon and pulled it back to the shop, its tail tucked between its legs. Looking at where the heavy equipment was still attacking the drift on the north end, I have no idea why someone thought a V plow was going to get through any of that.
   / Working rail roads and their tracks. #2,318
Big plans in my area for further commuter rail expansion!
Instead of spending another 380 million to extend the deteriorating catenary and stations on the rail line from Wawa, PA to West Chester, PA (our county seat and biggest town in the county), they are going to use a battery powered light rail made from recycled London underground cars!
Cars to be refurbished in Pittsburgh, PA :)
Not by any means the freight & passenger service that once was, but better than nothing?
Funny thing is all the rail cars and battery charging systems are being rented, not purchased.
   / Working rail roads and their tracks. #2,319
Stumbled across this. Enough to make a railroad fan get watery eyes. This is just PA & Ohio.
So much waste and crumbled infrastructure.
How could so much good go so bad?
   / Working rail roads and their tracks. #2,320
Often it is due to mergers, then abandonment of duplicate lines, them more mergers and abandonments of duplicate lines.
And loss of industries that need rail service, until the line operates at a loss, then abandonment.
And overbuilding of rail lines in the northern eastern part of the country before roads were good. See 1890 rail map below.
Bruce
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
1625 (A57192)
1625 (A57192)
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
