SmallChange
- Joined
- Apr 19, 2019
- Messages
- 763
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
Inspired by a thread in "Build It Yourself" called "A cautionary tale about fiber board bench tops."
I have my tractor happily stored in one bay of my barn (a wooden pole barn 3/4 of which is partitioned off and enclosed with wooden stickbuilt walls). There's a 35 gallon diesel hand-pumped dispenser, empty Eagle safety cans, and various small containers of lube oils and greases. Also electrical lighting, and a battery maintainer. No gasoline or propane. I don't weld in there but might occasionally grind. Nobody smokes, and I don't remember ever using a torch or heater in there.
I ought to get an extinguisher hanging in there near the door, huh? What else?
There's another part of the barn separated by plywood-on-lumber walls where I have a lawnmower and gasoline, and a gasoline standby generator, and propane tanks for grill and heaters and weed burner. That's also lit.
What do you do? I figure some ability to fight a fire that I accidentally start is in order, though if something starts in there without me I guess it's just calling the pros and standing back.
