Ford1000 injector connectors
   / Ford1000 injector connectors #1
reis
Ford 1000
Can someone please show how these lines are connected (please see photo) Thank you for your help :)
Sincerely,
Rick
   / Ford1000 injector connectors #2
they connect together and drain fuel back to the fuel tank. There should be a tube on the bottom of your fuel tank that they connect to.
Awesome, thanks for the info. Is it possible it connects to the top of the tank not the bottom ..... I see a little fitting that looks like the same size tube etc... see attached pic
   / Ford1000 injector connectors #4
No that is where your vent line connects, at least it did on mine. There was another fitting just like that one in your picture on the bottom behind the petcock on my Ford 1110.
   / Ford1000 injector connectors #5
Hmm.... interesting ~ the tank on this tractor looks just like the attached pict from the manual. And it doesn't say where line 26 goes, it just calls it a pipe, return. Hmm return from what ? maybe the injectors ? And I attached another pict of the tank with the hoses on the back like the manual show ..... not sure its function ...
   / Ford1000 injector connectors #7
Just a typical one on my 1700. It combines all over flow from each injector and theb to the tank.
JC-jetro, yes that looks just like the 1000. Does it connect back up to the top of the tank like in the photo I posted above where the tube is broken off ?
   / Ford1000 injector connectors #9
I think that's where the fuel return line from the injectors should connect to:
And I think there should be a clear fuel resistant tube here which will act as a fuel level gauge:
   / Ford1000 injector connectors #10
Yes It does.
Ford 555D Xtra-Vator 4x4 Extendahoe Loader Backhoe (A55787)
Ford 555D...
2017 Caterpillar D5 K2 LGP (A55302)
2017 Caterpillar...
Jack Daniels Metal Trucks (A53316)
Jack Daniels Metal...
1000 Gallon Propane Burner (A53316)
1000 Gallon...
Wright Sentar (A50120)
2018 FREIGHTLINER 122SD TANDEM AXLE DAY CAB (A56129)
2018 FREIGHTLINER...
