very hot -battery cable
/ very hot -battery cable #1
calfal
Member
lake charles,la.
kubota l275 power king 14/24 kioti ck27
hi all,, I have a older L275 Kubota ,,I replaced the alternator yesterday took the tractor for a ride also washed it at a pond,,drove it back to the parking spot,,about 2 hours later went to start it and the start would just click...I know the battery is good because I checked it after installing alt...any way I noticed the - battery cable was extremely hot..any body have any idea what is going on? it always cranked fine before is this a sign of a bad starter? your thoughts please...
/ very hot -battery cable #5
If you got water in the starter and drain hole is plugged, can be a short situation. Ive had them go bad job at from condensation. I've had them last a long time because I took apart and cleaned it up.
/ very hot -battery cable #6
A battery cable gets hot when the conductor inside the cable is carrying more amperage than the conductor can radiate away as heat. BTW, "current" and "amperage" are words that mean exactly the same thing. I don't know why we have two words for the same thing, both mean the QUANTITY of electricity that is being moved through the cable - just like voltage means the INTENSITY of the electricity. Because large cables are physicaly bigger, larger cables can radiate more heat and so they can carry more amperage without overheating.
For the L275, we can assume it worked fine and didn't overheat the cable before, so something new is causing the battery cable to carry more amperage than it should. It could either be that the cable itself is corroded inside the insulation so that there is actually less copper cable in there than there once was. In that case, the whole current or amperage to the starter is actually flowing through a smaller wire. I've seen that. Gets hot fast.
The best way I know of to check for cable corrosion is to split the cable insulation longwise for a few inches back from the battery and see if there is a lot of corrosion among the wire strands. If not, you can just tape the insulation back into place and no harm done. BUT, if there is a lot of white and green powder in there, then that powder used to be copper wire and the battery cable needs replacing.
BTW, cable corrosion happens with the old "wet cell" type lead/acid batteries with the water caps. It doesn't happen at all with newer AGM type lead/acid batteries.
If the cable looks good, then the only thing left is that the starter itself is drawing more current or amperage. In that case, the starter is probably getting hot too, and it won't last long. The cure for that is either rebuild the starter or replace it.
Best of luck,
rScotty
/ very hot -battery cable #7
The starter in my450c dozer was going out and the cable attached to the starter was getting quite hot.
Reman starter solved it; along with easy starting once again.
/ very hot -battery cable #8
Whatever it is - fix it!
Last summer, my JD X740 was parked in my airplane hangar, along with all my other toys. Whatever the fault with the X740 was, it spontaneously ignited at 4AM, and burned down everything. Don't "tolerate" electrical faults!
/ very hot -battery cable #9
Please disconnect the alternator that you just installed If you haven’t done so or the tractor has been engulfed flames by now. Something is wrong with the alternator install that is creating a dead short.
/ very hot -battery cable #10
Wow... sorry to hear that. The solution is a battery disconnect switch. It's common in some things. In fact, it would be rare to find a boat that doesn't have one. It's basic safety and common sense.
But tractors, cars, and trucks rarely have them because they are not operator convenient.
I'm no better. Our boats always had battery disconnects, and so does our camper and commercial equipment. But none of our cars do. And half the tractors don't. Maybe I should make that next year's project.... to put a manual battery disconnect switch on everything.
rScotty
/ very hot -battery cable #11
A positive electrical wire connected with the frame creating a short in the electrical wiring causing what you described as spontaneous combustion.
A couple years ago I was mowing with my old faithful 2084 Cub Cadet. I was mowing beside a building where I had mowed for years and the next thing I knew the mower was turning over. It landed on its side trapping my left ankle. I was laying there struggling to get my leg free and thought all I need is for this thing to catch afire. About that time I heard a poof sound and sure enough it was smoking and burning. I pushed and jerked with force then and freed my leg. Better scratched and lacerated than roasted.
I doused the thing with water to put out the flames. When I turned the thing over the battery slipped out of its holding strap allowing the positive battery to contact a metal part of the frame. This caused a short in the wiring. The hot wiring ignited the plastic side panels and hood, etc. The mower was a total loss.
thanks you all for your replies,, 1st I will change battery cables to ensure zero connection .. if that don't work I will try the starter route,, where I live the are no more starter/alt.shops everyone has died no one took there places..I did disconnect the battery from tractor and have a sola charger just on the battery,, thanks again for all the reply and suggestion.. every thing is closed for labor day so it might be Tuesday before I candy any thing..
/ very hot -battery cable #13
Make sure you have a good clean ground.especially at the end opposite the battery. I make my own ground cables with welding cable.
/ very hot -battery cable #14
if it wee me and i just replaced the alternator. before doing anything i would disconnect the + wire to the alternator ( the bigger one). If it sparks you need a new alternator.
/ very hot -battery cable #15
Glad you made it out!
In the E.R. some serious injuries come from simple mundane everyday life.
/ very hot -battery cable #16
. Blimey - talk about money to burn!!
Don't buy anything until you have thoroughly cleaned the battery cable connections & the earthing point(s) on the engine & chassis. 10:1 it's just a bad connection. Next thing is to check the cable terminations. If these are bad then just shorten the cable & use new terminals. Only if still bad do you need to go & buy new cables . Have you seen the price of copper these days?
  • Good Post
Reactions: JWR
/ very hot -battery cable #17
If it worked fine up until needing to replace alternator I would start there. Maybe a refurbished alternator and not redone correctly. If cables have not been replaced in tractors life time I would redo those. Have seen on several older trucks that the resistance of old cables can tax the rest of the charging and starting system causing parts to fail. I personally would not just redo the cable ends if corrosion is found under the insulation.
/ very hot -battery cable #18
You got water in the alt.
/ very hot -battery cable #20
You don't say which battery cable. Is it the positive from the battery to the starter solenoid? If the cable ends are hot it is probably a bad connection/corrosion there. If the cable itself is getting hot along its length, you have excessive amp draw. First recheck all wires you touched when doing alternator. Are they in right place according to the book? Always suspect your recent work when a problem occurs afterward.
Voltmeter tests you can do.
1. Put voltmeter leads on battery positive and negative when battery is at rest. Set at 20 volts. Should read over 12.5 v. ignition off, no draw. Turn on key and headlights. Voltage should not drop more than .4 volts. if there is a big drop, battery has a bad cell.
2. Visually check all connections and starter to frame ground to make sure contacts are all good.
3.Turn key to start, should be over 9.6 v. If below that battery has a bad cell or excessive starter draw.
4.Test battery with load tester before going further. A weak battery producing low voltage will cause excessive current to flow to starter and heat up wire.
Battery must be good for rest of tests.
5. Put one voltmeter lead on battery positive and other on end of positive cable where it attaches to starter solenoid. Leave meter set at 20v. range
Crank starter. If voltage is over .2 volts connections are bad. Over 1.0 volt is a bad cable. (You are measuring voltage drop in cable under load.)
6. If Test #5 shows less than .2 volts , leave one voltmeter lead on positive connection at starter solenoid. Put other lead on negative terminal of battery.
Meter should read within .1 volt of battery voltage. Crank starter. If voltage drops to 9.6 volt or less, and battery is good, starter is drawing excessive current.
Take apart starter, make sure lubrication of motor shaft is good, and armature is not rubbing on case or windings somewhere and brushes are free and clean off dirt on brush slides.
If the voltage stays above 11.5 volts or more and starter is slow or won't turn, there is an internal problem in starter.
If no visible problems, take starter to rebuilder.
7. To test ground circuit. Put one voltmeter lead on some metal part of the starter. make sure you have a clean connection. Put other voltmeter lead on battery negative post. meter in 20 volt range. Crank starter. If voltage is over .2 volt you have a bad ground connection somewhere. Make sure starter bolts to engine are clean and tight. Check and clean connections on ground strap from engine to frame. Check and clean end of negative cable where it bolts to frame. Check negative terminal on battery.
Probably you have something wrong related to your recent work or battery has a bad cell, but these voltage drop tests will let you isolate a problem quickly. If you replaced the alternator, I assume the battery was getting low and repeated starting with a low battery draws heavy current and can damage starter or cables.
(5) 3" X 20 GALVANIZED PIPE PLANE ON BOTH ENDS (A64281)
(5) 3" X 20...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
