Lighter weight log chains -- where to buy?
   / Lighter weight log chains -- where to buy? #31
Google “logging choker chain”.
   / Lighter weight log chains -- where to buy? #32
   / Lighter weight log chains -- where to buy? #33
Cable chokers weigh less than chain. I like cable chokers for pulling logs as the cable is easier to stuff under a large log. But they are a pain to carry on the tractor and store. Chain chokers can be dumped in a box. I got G100 chain chokers from westechrigging.com. G100 costs a little more than G70 but it's lighter for the same strength. I made grab rods out of scrap to make it easier to get the chains under logs.
   / Lighter weight log chains -- where to buy? #34
Here is a UTV towing trees with a 5/16 choker high grade chain. Loved it so much I got one for my personal use and store it in a plastic ammo can in the machine. No problem! (y)
Cable chokers weigh less than chain. I like cable chokers for pulling logs as the cable is easier to stuff under a large log. But they are a pain to carry on the tractor and store. [...]
I always have a cable choker or two made up for pulling up tree roots while landscaping. But I don't think I selected the right cable (wire rope) or maybe the right termination. For one thing, where the cable pulls through the end eye, it frays into tiny swords designed to give me tetanus. For another, the tight bend there permanently kinks and coils the cable, so I wind up with a rat trap of springy self-tangling cable. I'm just buying stuff at Home Depot or Lowes to make these up -- where and how do you make it better?
Wait, wait, maybe I just found what you are all talking about:
   / Lighter weight log chains -- where to buy? #37
Yep that's it. The bullet end goes into the sliding fitting and it grips the tree tight. The one problem with those is they lack a ferrule in the eye. So when you pull on it hard with something small diameter in the eye (like a chain you're using to extend your reach) the cable in the eye bends more than I'd like. I worry it'd eventually break. I added a ferrule into the eye and used a cable clamp to hold it in place. I'm probably over thinking this and it's fine for homeowner use.
I see what you mean. Well, at $33, this homeowner could take a chance. On the other hand, it'd be easy enough to use a chain slip hook with its wide rounded cross section to take the eye, or maybe get a ridiculously large diameter quick link to use with them.
   / Lighter weight log chains -- where to buy? #39
What is your intended use? If you are just moving small logs, these type of hooks as already posted are easy to put around a small log and easy to remove. Logging Chain Choker Hook 5/16" and 3/8" and Chain Slip Hook
If you are trying to pull up small saplings, but the chain is slipping, some use a pipe like this.
Personally, I just wrap the chain in a way that it tightens against itself when pulling saplings. A single wrap may slip up the trunk. A double wrap where the chain tightens against itself tends not to slip.
I'm not really a fan of wire rope.
   / Lighter weight log chains -- where to buy? #40
A local logger here in Mid Tennessee used his hand to run cable under a log and got bitten by a rattlesnake that was resting under the log. He was in/out of the hospital and eventually passed.
What does your grab rod look like?
2008 UTILITY DRY VAN TRAILER 53X102 (A57880)
2008 UTILITY DRY...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2016 Kawasaki Mule (A55973)
2016 Kawasaki Mule...
HUSQVARNA RIDING MOWER 42INCH (A56859)
HUSQVARNA RIDING...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
