Anyone else seeing signs of an early winter?
   / Anyone else seeing signs of an early winter? #1
KilroyJC
Elite Member
Appalachia
1962 Case 430, 1995 Craftsman Yard Tractor/mower, 1949 South Bend 9A Lathe, WoodMizer Lx55 sawmill, Kubota KX033-4 Mini-Excavator
A couple weeks ago, a black walnut in town started dropping some fully-matured walnuts.
two weeks ago, the orb weavers started up.
last week on YouTube, someone about 40 miles away posted that their “persimmon seed reading” says early and frigid winter.
today, while out walking about, I have seen multiple sycamores, maples, butternut and black walnuts with leaves turning yellow.
We are in western North Carolina at about 2200’ elevation.
   / Anyone else seeing signs of an early winter? #2
500' in Maryland I've noticed early leaves on the ground, all different species.
   / Anyone else seeing signs of an early winter? #3
not even close around here
   / Anyone else seeing signs of an early winter? #5
BAD THREAD :)
I want an endless summer, then fall, then spring
BAD THREAD :)
If you want fall and spring, you pretty much can’t have an “endless summer”. . .
   / Anyone else seeing signs of an early winter? #8
just seeing if you were awake
   / Anyone else seeing signs of an early winter? #9
We've had trees dropping yellowing leaves but I put that down to how dry it's been.
And while I can understand how someone in BC might want an "endless summer" I'd prefer spring, a short cool summer and then fall.
   / Anyone else seeing signs of an early winter? #10
Grass not growing as quick anymore ferns starting to turn brown,other than that as of last year.
AMQ45 Hydraulic Quick Connect (New/Unused) To fit CAT345 (A59225)
AMQ45 Hydraulic...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2347 (A58376)
2347 (A58376)
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
(INOPERABLE) GEHL 8K TELEHANDLER (A58216)
(INOPERABLE) GEHL...
