2008 Nortrac 254. I was admittedly overtasking my tractor digging with the FEL in 4wd when I heard a "clunk" and lost my 4WD. It was my own fault but now I need to figure what is wrong. I need some help. Here is what I have done. I was hoping it was the drive shaft or a universal slipping. But it's not.
I need some advice on next steps. I think I need to get inside the front differential but I am not sure the best approach. Take off the rear support right behind the differential or the front differential support or start somewhere else? Any idea where or what the probable failure is? I do have a good diagram but still where to attack it from where I can inspect was is happening inside.
I appreciate any insight in advance!
- Jacked up all four wheels
- No clunking, clanking, or clicking anywhere.
- Tractor shifts in and out 4WD
- In 4WD and tractor running in gear all four wheels are spinning
- In 4WD with tractor running and in gear, I can stop both front wheels from spinning with my hands
- Rear wheels continue to spin
- The front drive shaft continues to spin and looking at the front drive shaft connection to the front differential, with the metal sleeve cover pulled back, everything I can see continues to spin.
- If I remove my hands from the front wheels, they begin spinning again
