Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,280
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
You can weigh round bales with it:
Those things call for an x. They are so good because they don't do much else. Skid for grading moving stuff. X for digging. Tractor for mowing.I don't want three machines. The Kubota is fine for moving logs, bush hogging, and doing little forklift jobs. It's no good for removing stumps and rocks, digging, and knocking trees over.
I guess those are the three jobs I would really like to do. I don't have to move machine tools every day.
It is 16" from the front of the tire, to the front of the SSQA plate.Xfaxman,
If you lower the boom to horizontal and run the boom all the way to its extent, What is the length from the front of the machine ( not the boom pivot point ) to the end of the boom without any attachment on it?
12 feet would be 62" added on the SSQA plate.What weight can it lift if you have 12 feet extended out in front of machine?
Thanks. I was curious about its specs at full extension since I am trying to get better handle on what the M59 can do and you have a load cell and a good understanding of what your machine can do.It is 16" from the front of the tire, to the front of the SSQA plate.
The inner boom slides out 66", so it would be 82" to the front of the SSQA plate from the front of the tires.
This is what I have pictures of:
Without the bucket and the boom fully extended, at 15 degrees, it took 3943 lbs to raise the back wheels off the ground.
View attachment 754091 View attachment 754092
If you need to know exactly I can put the stump bucket on and measure it at 12 feet
The Kubota will lift 1500 pounds, and I had to drag this rock. It's as long as a small couch.I am guessing that is about half the size of the one above.
I have a 5k crane scale. Tried to measure lift power, but the scale goes to overflow if over 5001 pounds:
