Yesterday. Would you buy and EV?
Status
Not open for further replies.
   / Yesterday. Would you buy and EV? #301
One issue with EVs in hilly or mountain areas is the advertised range might not be so great, especially running the HVAC and more so after the batteries get some age on them. Repeated fast charges also seem to reduce battery life along with driving in extreme temps.
In limited city driving, I think they make better sense than in taking a long vacation trip in July.
Hybrids have the advantage of range, but the disadvantage of having both electric and fossil fuel drive components. Not sure every mechanic other than the ones at the dealers are equipped to service them.
For your daily driving needs use the same roads and use Regen mode to turn the mountains into level driving roads. :)
   / Yesterday. Would you buy and EV? #303
The larger 52” EGO zero turn equipped with six 12aH batteries is priced at 6999 at my nearest Ace Hardware. It says up to 4 acres of cutting time, so I believe it should do the two acres I mow. I’m on my second season with an EGO push mower for trimming around the house and fruit trees. So far it has performed very well with the one exception being the battery run time is overstated. I’ll drop a second battery in the charger before I start trimming when the grass is high or damp, in case I don’t make it. My wife thinks I should try the 52” EGO and sell the 1023E I’m currently using to mow. I’ve enjoyed the no gas or lube in everything electric that I have so far. With the direct drive mower spindles there is no belts or greasing either. Maybe she is right.
I don't know how bumpy your ground is, but keep in mind, the ride on your tractor is likely much smoother than it will be on the EGO. I know this for a fact because on the tractor you have a much larger foot print to absorb irregularities on the ground.
I wasn't prepared for how much I would be feeling every dip and rise in the ride. The adjustable suspension seat helps some, but it is in no way comparable to a real suspension seat.
Having said that, I do have lower back problems. You might have a different experience on your property.
   / Yesterday. Would you buy and EV? #304
   / Yesterday. Would you buy and EV? #305
   / Yesterday. Would you buy and EV? #309
Status
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
UniCarriers Propane Forlift (A56857)
UniCarriers...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
VERMEER V6500 COMBO TRENCHER (A52708)
VERMEER V6500...
72in Boom Lift Basket (A56857)
72in Boom Lift...
2017 Ford F-150 (A56858)
2017 Ford F-150...
