Looking at an Allis Chalmers 5015
   / Looking at an Allis Chalmers 5015 #1
mgsolakis
Member
Ontario, Canada
Case 446
I'm looking for an upgrade on my Case 446 and I found an Allis Chalmers 5015 in good looking condition for a decent price. Are there good tractors? Would I be able to find attachments for it? Or am I better just finding a Yanmar or Kubota of a similar size? Thanks
   / Looking at an Allis Chalmers 5015 #2
Allis Chalmers 5015​
Allis Chalmers 5015 tractor photo
1982 - 1985
Sub-Compact Utility tractor
Hinomoto built
Series:50155020
5215
Production
Distributor:Allis Chalmers
Manufacturer:Hinomoto
Type:Sub-Compact Utility tractor
Factory:Osaka, Japan
Original price:$6,549 (1985 )
The Allis Chalmers 5015 is the same as the Simplicity 9518.
Allis Chalmers 5015 Power
Diesel Engine:18 hp
13.4 kW
PTO (claimed):15 hp
11.2 kW
Allis Chalmers 5015 Engine
Toyosha 1.0L 3-cyl diesel
Mechanical
Chassis:4x2 2WD
4x4 MFWD 4WD
Cab:Two post ROPS. Optional ROPS canopy.
Transmission:9-speed gear
Dimensions
Wheelbase:50.8 inches
129 cm
Length:82.7 inches
210 cm
Width:40.9 inches
103 cm
Height (steering wheel):46.9 inches
119 cm
Height (hood):40.9 inches
103 cm
Clearance (front axle):13.7 inches
34 cm
Clearance (rear axle):14.2 inches
36 cm
Allis Chalmers 5015 Weight
2WD Shipping:1278 lbs
579 kg
4WD Shipping:1448 lbs
656 kg
Power Take-off (PTO)
Rear PTO:continuous
Rear RPM:540 (1.375)
   / Looking at an Allis Chalmers 5015 #3
It appears the AC 5015 has a Category 1 TPH, so implements should not be a problem.
Other than mowing turf, a 1,400 4-WD tractor is not going to be capable of much ground contact work. A 2-WD model will be capable of less.
Parts probably difficult to impossible for a 36 year old machine, imported for just three years.
If it has a Loader the tractor will be very tippy due to high ground clearance for a subcompact tractor.
   / Looking at an Allis Chalmers 5015 #4
J.I. Case 446​
J.I. Case 446 lawn tractor photo
1972 - 1988
Model year 1972-19761977-1988
400 Series
Garden tractor
Series:444446
Production
ManufacturerJ.I. Case
TypeGarden tractor
FactoryWinneconne, Wisconsin, USA
Dimensions
Wheelbase48 inches
121 cm
Length72 inches
182 cm
Width41 inches
104 cm
Height (steering wheel)43.3 inches
109 cm
Height (hood)38.5 inches
97 cm
Shiping weight770 lbs
349 kg
Ground clearance11 inches
27 cm
Front tread33.5 inches
85 cm
Rear tread31.5 inches
80 cm
Thanks for the input Jeff, I mostly use the tractor for mowing grass, but I'd also like to be able to move boat trailers as well as put either a loader or dirt scoop on the back for moving soil around the property. I won't need to do any heavy duty dirt work. What you have you or anyone else on the form suggest?
There is a Kubota L245DT which would be a little bigger with a wider wheel base. I would have to replace the tires with more turf friendly tires, not sure how much that would cost.
   / Looking at an Allis Chalmers 5015 #7
I mostly use the tractor for mowing grass.
Moving almost any trailer will require front end weights, or the tongue weight of the trailer will have the very light tractor vertical, rather than horizontal.
You can certainly mow but be aware that the PTO is CONTINUOUS on this tractor.
I doubt the 1,400 pound A.C. will have enough traction to scive up dirt with either a TPH scoop, or a FEL bucket.
Finding an FEL for a non-standard 41" wide tractor would be a miracle. Then you would need numerous hydraulic bits and pieces to power the FEL. If you find a Loader, the tractor will be very tippy due to unusually high 14" ground clearance for a subcompact tractor.
( Parts probably difficult to impossible to find for a 36 year old orphan-brand machine, imported for just three years.)
   / Looking at an Allis Chalmers 5015 #8
Kubota L245
Kubota L245 tractor photo
1976 - 1985
L Series
Production
Manufacturer:Kubota
Type:Compact Utility tractor
Factory:Japan
Original price:$4,000 (1977 )
Variants
L245:2WD
L245DT:4WD
L245H:high clearance
Kubota L245 Weight
2WD Shipping:1825 lbs
827 kg
4WD Shipping:2000 lbs
907 kg
4WD Operating:2382 lbs
1080 kg
Ballasted:3792 lbs
1720 kg
Engine Detail
Kubota DH1101
diesel
3-cylinder
liquid-cooled
Displacement:68.3 ci
1.1 L
Bore/Stroke:3.00x3.23 inches
76 x 82 mm
Power:25 hp
18.6 kW
Air cleaner:paper element
Compression:21:1
Rated RPM:2800
Starter:electric
Starter volts:12
Oil capacity:5.2 qts
4.9 L
Coolant capacity:7 qts
6.6 L
A much more capable tractor.
So the Kubota does not have a live PTO? A continuous PTO would not be ideal to my application.
   / Looking at an Allis Chalmers 5015 #10
Kubota L245
Rear PTO:independent
Rear RPM:540/700/1000
'Independent' is the most desirable type of PTO.
Unless you have water-retentive clay soil the R1/ag tires shown in the photo should be fine on lawns with only 2-WD engaged.
The tractor is only 2,380 pounds.
Likely the tire tread is fairly worn.
If you will pull boats up wet boat ramps, wider, softer turf tires might improve traction. Sharp sand and/or cat litter will also help tires grip wet concrete. You will need new rims as well as tires.
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A58017)
2005 INTERNATIONAL...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
