Ground squirrels
   / Ground squirrels #1
Nikkorott
Central Valley, Ca.
MF 30E, BCS 832, Deere 3720, Ferrari 95
I tried something today that I have a feeling could be a cross between an Elmer Fudd and Wiley Coyote plot. I have had an issue with ground squirrels for awhile now. Our muni folks put poison out once in awhile. I've never to thrilled about that. Some neighbors will use those poison gas/flare things. I've used dry ice but that gets expensive. My newest idea is using a leaf blower and cayenne powder.
Has anybody on this board tried this before? I put the end of the leaf blower in the hole. If it's not blowing gobs of dust & dirt back out at me, I pour a little bit of the cayenne powder into the suction. When I'm doing this I'm wearing safety glasses and a mask. If you try this make sure that you know your pepper tolerance! You WILL get some blow back.
Good luck!
   / Ground squirrels #2
I'd be pretty shocked if you could get it in far enough to have a real affect on them...if they reacted to it at all.
   / Ground squirrels #3
I like it, but they have so many exists you might get hit from behind! My trick requires a helper, my 10 year old jack Russell.
I have a few 4 inch pipes under my deck. When I let my dog out, he checks to see if there are any critters in the pipe. If yes, he barks. I then go down to do my part. I carefully pick up the pipe and quickly stand it on end. Then with my dog's nose at the end I slowly tilt it back. squirrel nose pokes out and he crushes their skull!
He has killed 5 this week alone...
In my mini orchard I set rat traps. A smear of peanut butter topped with sun flower seeds, also very effective
   / Ground squirrels
I'm wondering if I'll have taco flavored pomegranates for Thanksgiving. :p
   / Ground squirrels #5
If by ground squirrels you mean gophers the best way to rid yourself of these rodents is the cinch trap.
I tried various methods but with the cinch trap I was able to rid myself of all of them. Easy to use and works quickly.
   / Ground squirrels
No. Ground squirrels are different. For gophers I've had really good luck with a trap called a Gopher Hawk.
   / Ground squirrels #7
I tried pouring Dollar store black pepper, cayenne pepper, and chili powder down chipmunk holes. Don’t know if it did any good but was fun thinking about their effects. I finally live trapped 4-5 and gave them a 30 mile ride to work. In North Georgia back then.
   / Ground squirrels #8
We have chipmunks. They burrow everywhere. I tamp down the burrows when they pop up and count it as free lawn aeration. Never kill a snake.
   / Ground squirrels #9
I don't know about California ground squirrels. Here, we have 13 lined ground squirrels. As kids, we'd take a couple quart canning jars full of water and chase the ground squirrel until it ran into it's hole. Then we'd dump one, then two jars of water down the hole and put the last jar over the hole. Give it a couple seconds and the ground squirrel pops up in the jar. You quickly tip the jar and put the lid on it. Worked surprisingly well. But, then you have a squirrel in a jar. Then you wondered why you did that. Then you felt kinda bad about that and let it go and went and found something else to do.
   / Ground squirrels #10
Ok I've heard others complain about ground squirrels so I must ask if we are talking about the same thing.
We call these ground squirrels and they don't cause noticeable damage to anything. Ground dwellers that cause damage are called gophers and prairie dogs.
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2010 Ford F-150...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2025 K4525G UNUSED Double Garage Steel Barn (A50860)
2025 K4525G UNUSED...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
