What happens if your hydraulic reservoir is overfilled?
   / What happens if your hydraulic reservoir is overfilled? #11
If it’s a lot over full you could blow out seals. If it’s a gallon over full nothing will happen.
   / What happens if your hydraulic reservoir is overfilled? #12
That's why I put the green dye in my hydraulic fluid so I can see the level in the glass bubble
Hi DonaldP - In all the times I've made that offer you are the first to take me up on it ! Please let me know which info was bogus - and 12 years later "prompt" isn't possible -but cheerful is :)
hmmm… well to be honest, there wasn’t any “bogus” content, but I’m one of those people that are always reaching for the stars! You have great insight. I appreciate your input here. Don
   / What happens if your hydraulic reservoir is overfilled? #13
   / What happens if your hydraulic reservoir is overfilled? #14
I was just checking out the service manual for the L3650 HSTC.
In all the documentation I didn't find anywhere, comments related to overfilling and any issues that might cause.
From following the Hydraulic schematics, there is nothing there to show that a higher level could, or would cause any issues unless they might have left out any foaming or air entrapment due to areas where there may be return oil flowing back into the reservoir under pressure and mixing at a higher level in the return area. This is just my thought based on the schematics and the documentation I have reviewed.
As a reservoir, the holding area seems big enough to support additional fluid. The last time I picked up my unit from the dealership it was filled up over the top of the upper dipstick mark about the same amount as the space between the marks. Given the level surface area inside the rear end assembly where the oil is stored, that could be a gallon or more of extra fluid there, maybe 2 gal (at my current Dealers installed level).
I agree though, once you get to a certain point lots of other things come into play... there could be head pressure that might impact some control valves that may be normally looking at atmospheric (or the internal air pressure of the housing - if that is different) pressure as a normal - but that atmospheric could be increased by the weight of an additional 2 to 5 gallons of fluid.
There is no question that we aren't privy to all the design considerations that make up the operating characteristics of a complex hydrostatic design like this, so we probably need to be within a prescribed level relating to the manufacturers specs. Yes, every time I connect or disconnect an implement (depending on the connectors), there is a loss of oil, that's just the nature of the beast. However, I would venture to guess that without major leaks, you could get quite a few connects and disconnects on various types of hydraulic implements or equipment before an appreciable loss in fluid would negatively impact the functioning of a tractor that has a reasonably maintained hydraulic system. Not to mention that a daily or weekly check would also point out those issues hopefully before it causes operational issues.
Oh, and, by the way , I'm still waiting for rbargeron's guaranteed refund!! (Not that he made any disclaimers that weren't true), he he he ... last I heard was "it's in the mail", but that was over a year ago. I'm thinking with COVID, the mail is just delayed a bit or maybe the mailman thought it was a Ballot from the last presidential Election and tossed it in a field somewhere. It should have sprouted by now!!!!
   / What happens if your hydraulic reservoir is overfilled? #15
That's why I put the green dye in my hydraulic fluid so I can see the level in the glass bubble.
Use FD&C Green number 4!!! Just in case you end up getting hit the face with some oil from a leaky hose. You would want it to be Food grade dye !!!!
   / What happens if your hydraulic reservoir is overfilled? #16
I overfilled mine when I changed it , It's easy to do . I drain a little and topped it off slowly to the right level. I would say nothing will happen . But I didn't want to take a chance and have any seals leak.
Just read kennyd post and that makes sense
WaxMan ... are you still in the drivers seat?
   / What happens if your hydraulic reservoir is overfilled? #17
What type of green dye do you use in the hydraulic fluid? How much would it take for 9 gallons?
   / What happens if your hydraulic reservoir is overfilled? #18
Specifically on a B21. I overfilled it. I am going to drain the extra. But it leaves me wondering what happens if you have too much fluid?
Long as it has a couple inches of expansion space, should be no problem. Long as you don't have any water in it that would cause it to possibly foam.
   / What happens if your hydraulic reservoir is overfilled? #19
   / What happens if your hydraulic reservoir is overfilled? #20
The last MT3668 I purchased the label on bottle was green but the dye was red in color
UNUSED PABREAK PC463 - 72" HYD PLATE COMPACTOR (A57193)
UNUSED PABREAK...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
UNUSED FUTURE 40" HYD TILT MINI EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 40"...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
