Buying crushed rock -- new MSHA rules?
   / Buying crushed rock -- new MSHA rules? #21
$50/yr and proof of insurance
   / Buying crushed rock -- new MSHA rules? #23
That's likely for the Permit. The goobermint always wants their pound of flesh. I doubt they care much about who puts the gravel down. But each County can be different and so can municipalities within those Counties. Some of them don't care, some are downright Karen-ish about it.
   / Buying crushed rock -- new MSHA rules? #24
The Ready Mix stone yard I use hitched a one yard Wet Mix concrete gondola to a half ton Bumper Ball Mount with safety chain...
It broke loose, bumper and all and a pedestrian in cross walk badly injured...
After that things changed...
   / Buying crushed rock -- new MSHA rules? #26
As someone mentioned, it's probably insurance and liability reasons... or....
They just don't want to bother with small potato customers anymore.
The world needs more lawyers and bureaucrats. The covid lockdowns were initiated to make sure too many of them didn't die off.
   / Buying crushed rock -- new MSHA rules? #27
It must be new state law, as you are the second person from Washington state who mentioned this yesterday.
Or perhaps Oosik was second, but I read his post first. ;)
   / Buying crushed rock -- new MSHA rules? #28
That’s a very hard way to haul rock. I did that in my truck once and hand shoveled the rock out of the truck bed. Never again.
I've things that makes it relatively easy:
A Loadhandler
Good plywood and tarps
A son, now about 40, with a strong back.
For a while there we'd go and pick up about 3 or 4 loads a year, usually about 2 tons at a time.
He'd push off the top of the pile then with the Loadhandler we'd crank off the rest.
Since the stone yard is only about 10 miles away it is very economical.
   / Buying crushed rock -- new MSHA rules? #29
In Texas a commercial contractors license doesn’t really exist.
   / Buying crushed rock -- new MSHA rules? #30
A Loadhandler
Locally you can hire a tri axel dump truck for $100 plus the product cost. At least you could before diesel went to $5 a gallon. And the quarry is probably charging you a higher unit cost than the dump trucks. Making 10 trips to save $100 doesn’t sound very economical to me.
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
2018 Freightliner M2 106 Medium Duty AWD Altec AA55 56ft Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
HUTCH 3000 SEED CLEANER (A52708)
HUTCH 3000 SEED...
2022 Lonestar 14ft. 5 Ton T/A Utility Trailer (A55973)
2022 Lonestar...
