Should I use conventional oil, or synthetic oil in my tractor.
   / Should I use conventional oil, or synthetic oil in my tractor. #51
For me it's very simple. I use the oil grade recommended in my Owners Manual. I use Rotella T4 - 15W40.
Most also recommend 10w30, which means 0w30 would be the absolute best. The 15w40 is absolute goo in cold weather. Your overhead valve gear probably is smoking by the time oil ever hits it.
   / Should I use conventional oil, or synthetic oil in my tractor. #52
I actually found T6 in stock at Walmart yesterday. I was excited and grabbed a 2.5 gallon jug. Then I saw it was only available in 15w-40 and put it back. I change oil annually, not seasonally.
   / Should I use conventional oil, or synthetic oil in my tractor. #53
That's all that's around here-1540. I need 540.
Changed over to the Farm-Rated stuff yesterday. True enough, has CJ, but not CK rating. CJ is adequate for my machine.
Maybe Rotella will become more available at some point and this stuff can become my spring change stuff.
   / Should I use conventional oil, or synthetic oil in my tractor. #56
There’s several grades (Heavy Duty and Signature Series) and viscosities of diesel oil available from Amsoil. Check it out online yourself and you can choose one you would prefer and the corresponding price. Free shipping with $100 I believe. I’m in Canada so it’s different for us up here… Wouldn’t use anything else myself.
   / Should I use conventional oil, or synthetic oil in my tractor. #57
Amsoil 5W-30 synthetic diesel oil; $124/gallon.
Valvoline 5W-30 synthetic diesel oil at my local Cummins shop; $30/gallon. I can buy 4 gallons of Valvoline for the cost of one gallon of Amsoil.
   / Should I use conventional oil, or synthetic oil in my tractor. #58
Did it take some searching to find such a rip off price!!!!!!
Here are the actual prices;
and the one is less then your valvoline
   / Should I use conventional oil, or synthetic oil in my tractor. #60
Can buy a 5 quart container of M1 0w30 ESP for $39 at Advanced Auto. It's rated C3, light diesel use. Our tractor engines are not steam ship nor locomotive diesels.
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A48081)
2024 iDrive...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2007 Ford E-350 Cargo Van (A48081)
2007 Ford E-350...
2015 BMW X1 sDrive28i SUV (A48082)
2015 BMW X1...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
