6 Foot Howse, Is It Worth it?!
   / 6 Foot Howse, Is It Worth it?! #11
Just cut 4 feet wide,, rather than the full 6 feet,,
I used to do that with an old tractor I had,, and a 6.5 foot wide mower.
Done the same...only "problem" is the first pass which meant the entire width of the cutter...then, if the engine bogs, just slow down
Decades ago, I ran a 5" cutter behind a Deere 670 (19 HP, 16 or 17 PTO HP). over a powerline right of way that bordered my property. (power company, even after complaints, did little to maintain the property
Anyway, the 5' cutter did a pretty good job...for such a small tractor
   / 6 Foot Howse, Is It Worth it?! #12
My JD 650 came with a 60 inch mower,, a Woods RM59.
since the tractor had a "dead" pto,,, if you got into too heavy of a stand of grass,, the pto shaft would shear the shear pin.
That was tough when making the first pass, like you said, you were forced to take a full width cut.
   / 6 Foot Howse, Is It Worth it?! #13
Neighbor has an old 5' Howse and it has been a good cutter with no problems.
   / 6 Foot Howse, Is It Worth it?! #14
at $500 id say you can’t go wrong but yeah it had some used you can see the circle of the blade through the sheet metal … id have a look at the blade also … id say offer him $400 … a new one is what $1500 ??
   / 6 Foot Howse, Is It Worth it?! #15
Add about $1200
Copied from Howse website:
6' Economy Cutter With Chain Guards
$2,715.00
If you don't want the chain guards, knock off about $400
   / 6 Foot Howse, Is It Worth it?! #16
probably a good deal. believe it's a finish cutter, just to keep in mind for use. neighbors on either side of me have 5' finish mowers. the mt has beat them up a lot, but they're still operable. probable worth your 2nd hand deal, but i'd never consider investing in a new finish mower for my application. regards,
   / 6 Foot Howse, Is It Worth it?! #17
Sounds like a good deal and it sure seems like you have enough tractor for it. I thought the rule was 5 hp per foot of mower.
   / 6 Foot Howse, Is It Worth it?! #18
Nah, that's a rotary cutter (aka brush cutter)
   / 6 Foot Howse, Is It Worth it?! #19
ok i stand corrected, the deck height looked narrow. just a comment on finish mowers on rough terrain. my neighbor's finish 5' Howse has been a thorn on my side as i do his mechanic work :) cheers
According to TractorData.com, your Kubota has 32.5 PTO HP
That's probably more then the OP's 3032E and 3038E has...a 5' cutter would likely be a better fit. That said, for $500, he should consider buying it and seeing how it works out for him. Might just do a great job, if just field grass...
My Deere's have 25 and 30 PTO hp. I am most interested to see if the 6 foot vs. my 5 foot brush hog makes any real time savings on certain areas I mow. The areas are a bit rough so travel speed is limited. So if you can't mow faster, mow wider!
The Frontier RC2072 has a minimum PTO rating of 25HP so it is my choice if I can justify it!
So before I spend a bunch on a good 2072 I'd like to get a feel for how the tractors handle a 6 footer in general.
This Howse seems like a lighter duty one so I think it won't sap too much power from the tractor.
No one has really screamed "stay away" from the Howse so it may be a good one for the price point if it is in decent mechanical condition.
We'll see in a couple days when the snow melts.
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
FIAT ALLIS FD145 CRAWLER DOZER (A52707)
FIAT ALLIS FD145...
20' Shipping Container (A56469)
20' Shipping...
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
UNUSED PABREAK MPB232-72" HYD 4IN1 BUCKET (A57193)
UNUSED PABREAK...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
