OP
etpm
- Joined
- Jun 30, 2021
- Messages
- 2,054
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Thanks for the reply. I did consider the dumping capability but if I hadn't your reply would have reminded me to do so. The bucket now curls way more than necessary to dump. It really appears as if the cylinders were assembled with the wrong length rods. Fully retracted there is much more than 3 inches of rod exposed and I have never seen a hydraulic cylinder like this. Looking at the specs for my loader it curls forward way more than the what the drawing shows and way less back.Before you cut the rods be sure you will still have enough extension to fully dump the bucket. Adding travel on one end reduces it on the other unless the cylinders can extend past their current stops.
Eric
