BravoXray
- Joined
- Dec 17, 2019
- Messages
- 2,369
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
The door out onto the deck is original, 47 years old, the seal is getting bad, the thermopane window has lost it's seal, and the wood trim is getting pretty rotten, so I went to Lowes and looked at a new 32" X 80" steel exterior door. They only had one with the built-in shade, which I really don't want, but the ones without the shade, which is $100 cheaper, are special order, probably take six to ten weeks to get.
I asked if they could install it, the salesman said they could, and that installation was $299. That sounded a little high for an hour or two's work, it they know what they're doing, but fine, do it. He said they would have a guy come out and make sure there were no other problems and get back to me. The guy, nice fellow, came out the next day, looked it over, I pointed out that the threshold was partially rotted and he said they normally replace them anyway. I said I would replace the interior trim, all he needed to do was fix the threshold and put the door and casing in, I even already have the lockset and deadbolt.
So, the next morning, the salesman from Lowes calls and says that total for the door and installation will be ~$1180.
The door was $380, and the other $800 was for installation. He said normal install is $299, repairing the threshold was $250, modifying the header(???) was another $175 and the rest was for hauling away the old door. I don't know why the estimator said the header needed to me modified. there's nothing wrong up there, just a small gap (1/4") above the casing that has a couple of shims in it, no rot or anything.
I was pretty pissed, and just told him to forget it, I would do it myself.
Is that the going rate for a job like this, or am I just a cheap ass?
