Cutting edge for LS MT2 25S FEL
   / Cutting edge for LS MT2 25S FEL #1
BakoJ
Member
2021 LS MT2 25S
Hi there. Has anyone here added a bolt on cutting edge to the FEL of this machine? The bucket has five bolt holes and is 54" which is smaller than anything I'm finding online or locally.
   / Cutting edge for LS MT2 25S FEL #2
Great question - I'm looking for the same for my 72" bucket. I "think" I've seen mention that its sold thru the LS dealer but couldn't find any info on it.
   / Cutting edge for LS MT2 25S FEL #3
Piranha Tooth bar? seems to come in any size you could want. Quick search showed Titan cutting edges in 72 and 66 inch lengths.
   / Cutting edge for LS MT2 25S FEL #4
check with your LS dealer, I have a MT240 with the 66" bucket and I purchased an LS cutting edge for it, comes with the bolts and mounts in the factory bucket holes. For ref, my invoice is:
LST - Blade Kit - Bucket Edge 66, Item 40381448, cost was $256 in 2020.
There used to be a good video of it on youtube, but that video is unfortunately private and unavailable.
   / Cutting edge for LS MT2 25S FEL #5
I have 2 tractors with a standard toothbar and one with a pirahna, The pirahna is better for digging , clearing brush , and removing small trees. The standard bars also work well and are great for loading or moving things with a chain.
   / Cutting edge for LS MT2 25S FEL #6
Thanks for the links. Both the Pirahna and EA look pretty good.
Does anyone else's dealer charge 3x what I see online for LS parts? My dealer wanted over $1000 for a one sided, bolt-on edge.
   / Cutting edge for LS MT2 25S FEL #8
Some do for sure, I dont mind paying a little more to buy local ,but 4 times the cost of online is crazy.I called a local dealer to get an oil filter for my 2538 , Told me 100 dollars. Online was 12.
   / Cutting edge for LS MT2 25S FEL #9
I purchased one through my dealer when I bought the tractor new. Its a skid steer type with replaceable teeth. They drilled the each side of the bucket for the mounting system. It does not use the pre-drilled holes that LS has on the bucket. The tooth bar is produced by NAI and cost me $360 installed about a year ago.
https://northamericanimplements.com/collections/buckets/products/tooth-bar
   / Cutting edge for LS MT2 25S FEL #10
I ordered one from my dealer for $205. and been waiting on it and my backhoe thumb for 6 months now.
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
Kuhn FC400RG (A60462)
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500BBL WHEELED...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
