What is your favorite Quote or Saying?
   / What is your favorite Quote or Saying? #6,381
Sorry, both on wrong accounts.
Did you ever see how they built the original Panama Canal? Hardly more than guys with shovels. As far as doing a small job with a big tractor, I sure can think of many that are totally unsuitable for a Caterpillar 6090 FS. Most residential driveways would cave with its 1,000 ton weight.
Fair enough. I first became familiar with the quote when I was in the market for my first tractor. Like so many, I was pondering the question, "How big of a tractor should I buy?" I didn't want to waste money buying more than I need, and I didn't want to struggle for the rest of my life using a tractor that was under-powered for my needs.
Big and small are also relative. Some farmers would think my "big" tractor is tiny. I ended up buying a size up from what I was originally considering and never regretted it.
   / What is your favorite Quote or Saying? #6,384
You can do a small job with a big tractor, but you can't do a big job with a small tractor.
I will beg to differ... tight spaces using my BH. Had to remove my front bucket to navigate a tight turn just to get to the worksite. I could not have gotten into the space with a tractor larger than my BX.
   / What is your favorite Quote or Saying? #6,385
OK, so it's not a perfect saying! I still think the general idea is sound. ;)
   / What is your favorite Quote or Saying? #6,388
Close only counts in atom bombs and horse shoes.
   / What is your favorite Quote or Saying? #6,389
never let the truth get in the way of a good story.
   / What is your favorite Quote or Saying? #6,390
The farther backward you can look, the farther forward you can see
-Winston Churchill
2007 38ft. T/A Homemade Pipe Trailer (A55973)
2007 38ft. T/A...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
1998 PETERBILT 377 (A58214)
1998 PETERBILT 377...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
